Which Lifter.....Any Recommendations? Comp 850, Crane 10530?
Old 03-29-2006, 02:06 PM
jdoyle's Avatar
Default Which Lifter.....Any Recommendations? Comp 850, Crane 10530?
SETUP:
6.0 Shortblock
TR224 cam
Stock LENGTH Pushrods
Stock Rockers
853 heads milled .030
***Need any other info? lemme know
I have Comp "R" Lifters right now, but want to get rid of them since they are so noisy and the heads are coming off. Morels are kind of out the picture since they take so long to get and are muy expensivo.
I have called some local performance shops in Houston and was recommended Comp 850-16 many times, but heard the Crane 10530s in many cars, and are very quiet and the owners love them.
So which is better, Comp 850, or Crane 10530? should i look into something else? thank you very much
Old 03-29-2006, 02:18 PM
Cstraub's Avatar
Morels are in stock at a few of shops, I can think of Thunder Racing and Futral for 2 sponsors that have them in stock. Yes they are more money but with their rebuild program you only buy 1 set of lifters and when you go to build or refreshen the engine they will replace all worn parts, bodies and such for minimal charge and you have a new set of lifters. Can't beat that.
Old 03-29-2006, 04:26 PM
vettenuts's Avatar
If you saw the Morel's in person, you might change your opinion. On a dollar/lifter basis, $160 lifters are $10 each. Have to question how much quality can go in, and still have profit at that price. Just my opinion, but I went with the Morel's.
Old 03-29-2006, 04:42 PM
jdoyle's Avatar
hmmmmm......
i might have to talk to angie@thunder tomorrow too.
anymore replies?????????
Old 03-29-2006, 04:49 PM
Greg Fell's Avatar
Morels or stockers. I went with Morels.
Old 03-29-2006, 05:16 PM
jdoyle's Avatar
are they really quiet and easy to install?
also will have to change anything else in my setup? (read SETUP above)
Old 03-29-2006, 05:21 PM
vettenuts's Avatar
I was told the lifter body is longer, but the roller tip to pushrod cup is the same. So you should be OK. The roller is also slightly larger, so the roller RPM will be lower for any given cam speed.
Old 03-29-2006, 06:09 PM
jdoyle's Avatar
are they still good if they have a bunch of miles on em? cuz i dont wanna be messing with em a bunch.
Old 03-29-2006, 06:14 PM
vettenuts's Avatar
Huh????
Old 03-29-2006, 06:47 PM
jdoyle's Avatar
Originally Posted by vettenuts
Huh????
nvm, motor has a hole in the piston
whole diff set of probs now.
REBUILD?!?!?
I meant to ask if they need constant adjusting?
Old 03-30-2006, 12:08 AM
WhiteRhino's Avatar
I'm running the Crane replacements. They've only been in for about a month, but so far so good! I cant till a difference between these and the stock ones.
Old 03-30-2006, 12:35 AM
jdoyle's Avatar
is the part number for those the 10530?
are they quiet?
Old 03-30-2006, 12:42 AM
WhiteRhino's Avatar
I just looked it up.That is the part number. I dont think the lifters have alot to do with noise though. It mostly has to do with how your valvetrain is set up. I'm running those crane lifters with the Crane 1.8 accelerated lift adj rockers and Patriot gold springs and I think my valvetrain is quieter than stock.
Old 03-30-2006, 12:45 AM
jdoyle's Avatar
i gotcha, what preload are you running?
Old 03-30-2006, 12:49 AM
WhiteRhino's Avatar
I have them set at about .080
Old 03-30-2006, 12:54 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
lunati lifters are made by morel, same lifter. may help you out tracking one down. also not only is the roller and body stronger, but plunger is held with a snap ring, instead of clip, something to also look into.
Old 03-30-2006, 12:56 AM
jdoyle's Avatar
yup i think im gonna go with the cranes
money is too tight for the morels, gotta get a rear end under her
Old 03-30-2006, 12:57 AM
WhiteRhino's Avatar
I said the same thing about the morels. I'm sure they're great. Just not 3x's the price great.
Old 03-30-2006, 12:59 AM
jdoyle's Avatar
RyneZ06, all that stuff that you are talking about is on the lunatis?
Old 03-30-2006, 05:56 AM
PREDATOR-Z's Avatar
Man, all this is relative to the size of cam you plan on having. For lifts at or below .600, the 850-16 will be fine.
Mine have 47K miles on and 3 different XE-R cams. No issues. I'm only repacing them with a new set because i'm doing a total rebuilt 383.
Quick Reply: Which Lifter.....Any Recommendations? Comp 850, Crane 10530?
