Which Heads I need it with G5X3 and ....
Hi,
I will order this parts :
I am thinking about : PAT243 Patriot 243 Casting CNC Ported Heads (2.02/1.57 Ferra Valves - Assembled
but I want know what is the best one with all parts I will take it,
and how many HP and T do you think I will take with good tuning,
(NOTE : I am using my car daily)
Thank you,
Hani Sindi
Thank you,
Hani Sindi
For just a little more $$, I'd go with the stg2 p/p Dart 205s from Texas Speed. The smaller ports'll give ya more torque, and velocity will give you more topend. The only drawback is they're unproven.
DEFINATELY!! get the AFR 205s or if you feel like waiting in a long line ETP 215's or 225's. from what ive seen its a hit or miss with other heads. AFRs with the X3 and 90/90 setup will get you 465rwhp no doubt (as long as the other parts are in 100% working condition). do a search, there is NO other head that CONSISTENTLY makes 460-480rwhp on a stock cid setup...except AFRs.
by the way i had the G5X3 112, with the 90mm LSX & 90mm TB with absolute stage 2.5 heads and made 455rwhp/413rwtq. (loved it)
Have the AFR205s along with G5X2 cam (114LSA). Love it - good road manners. The fast 90/90 is a good recommendation. X3 is a big step up though and no comparison to the X2. As far as the tires, yeah - go wider (your axle should be in shape though) cause you might not. I run 275/60R15s and I consistently lose traction if I don't feather it, on my way from to second gear and then rip (not just chirp) once I hit 2nd....and this is with an A4, 2-piece driveshaft and 8.5" rear axle. Granted, I'm light in the rear compared to most camaros, but also weigh between 700 - 800lbs more.
Thanks for all
my car is A4, GTO 2004 (Lumina SS 2002)
What are you thinking about ET Heads ? is it more better then AFR ??
and what is the best choise between :
1-Patriot 243 Casting CNC Ported Heads (2.02/1.57 Ferra Valves - Assembled
2-Patriot LS6 5.7 - STAGE 2 (2.02/1.57/64cc)
Thank you,
Thank you,
Originally Posted by ss2002
Thanks for all
Thank you,
Thank you,
out of the 2 patriots, id get the LS6 style.
afr is the the head known to put good power out of the G5 cams, but then comes the should i spend the extra money for them. You get what you pay for you just have to decide how much you want to pay.
Justin
Justin
Originally Posted by PREDATOR-Z
Yeah, AFR 205's but you'll need to flycut the pistons to reach the hp number said above.
LG setups used 59cc AFR 205's.
I always have alot of respect for what you have to say. Just want you to know, he can order regular AFRs through LG - just needs to specify what he'd like. I've done it. He can tell them what he'd like.
Best Regards....
I'm right in the middle of insalling a X3 copy cam and some TEA 5.3's that are milled .050", 59cc's. The cam is a 234/242 591/601 lift 114 lsa. I'm running a stock bottom end.
I'm running into major PTV cleance issues. I've had to cut a ton off of the pistons.
I'm useing comp promagnum 1.75 rockers and 7.350 PDs, stock .048 gasket.
We are going to measure everything out tomarrow night to see if this is going to fly.
If this does'nt work I will be pissed.
I wish I would have bought the AFR 205's now. And still might have to.
Originally Posted by 93ChevExt5.7
Hi PREDATOR-Z,
Best Regards....
Best Regards....
He could run this combo out of the box but will not achieve these numbers for sure, more in the 440 range.
Yeah, of course, What I meant is that for him to get a G5X3/AFR combo that make in the 480+ rwhp, he would have to flycut since the heads will have to be milled to 59 cc (don't forget the .040 gasket).
Originally Posted by JRracing
How much flycutting do you think might be needed for this to work?
I would guess that 4>6 cc reliefs will work.
1 Post
Just back from LG Motorsports and made 460 rwhp 420 rwtq on the G5X3 114 and AFR 205 59cc Package. All the other bolt ons as well. They had to flycut my pistons, but no problem. AFR 205's are absolutely amazing. Before heads, pully, and Meziere electric water pump I had 400 rwhp, and after making 460. I would definately go with AFR heads over anyone else. They are proven time and time again. As the saying goes, "you get what you pay for".
