Best Cam to fit my needs POWER!
Old 04-04-2006, 11:46 AM
bLkWdOw SS's Avatar
Default Best Cam to fit my needs POWER!
I own a 2000 SS camaro with SLP LongTube's, SLP High Flow Cats, 3" piping, SLP Loudmouth exhaust. SLP Lid, LS6 Intake, High Flow sensors, At this point Im in need of a T/B. The last mod before I want to get the cam in. The kind of cam I wanted was maybe something that will have its nice idle sound to it, make you get chills when you hear it coming down the street. I dont want something to heavy for the motor. I DONT have the money to rebuild. And I use the car allot so maybe a cam that wont get me 5mpg, what are my options? Any recommendations with my current setup? Soundclips? Your help is very appreciated
Old 04-04-2006, 12:11 PM
SHINER's Avatar
I like the TR224 from thunder racing with a 112 LSA for your lopey sound needs. Just dont get something with such a high lift on it. GM makes a ASA Hot cam, expensive but I really like it. Its got a more radical duration than the TR224, and only a .525 lift instead of a .581 lift like the TR224 which is great!, and best of yet it has a 110 LSA its gonna lope like a ****. Tell me what ya end up getting
Old 04-04-2006, 12:23 PM
GR8GAME's Avatar
LS1Tech 10 Year
Does more duration make more power?
Old 04-04-2006, 01:00 PM
SHINER's Avatar
yea the higher the duration more power, thelower the LSA the more lope ur gonna have
Old 04-04-2006, 01:08 PM
mike c.'s Avatar
bigger cams tend to make more power. the g5x2 112 from LG-motorsports has the cam sound you're looking for and the power to back it up. i've had it(i have x4 now) and with a good tuner it drives verry,verry nice on the streets. LG-motorsports had a g5x1-g5x2-g5x3 and g5x4 cams,thet have something for your needs. take a look at their site. goodluck to ya.
Old 04-04-2006, 01:25 PM
Xtnct00WS6's Avatar
Not to be a picky bastard or anything, but the TR224 has .563 lift not .581. You're probably thinking of Comp Cams.
Old 04-04-2006, 01:35 PM
GR8GAME's Avatar
LS1Tech 10 Year
Do they make the .581 lift on a 114 LSA so I could still pass smog? (sorry for hijack)
Old 04-04-2006, 01:48 PM
SHINER's Avatar
No prob I like being corrected sometimes
Old 04-04-2006, 05:05 PM
silverTA2002's Avatar
Comp cams does.
I have a 220/224 .581 114lsa and love it for an M6.
If I had an auto, I'd go with a bigger cam.
Old 04-04-2006, 05:43 PM
SHINER's Avatar
You can have ANY type cam custom ground for what you want!
Old 04-04-2006, 05:56 PM
GR8GAME's Avatar
LS1Tech 10 Year
So that 220/224 would make more power than the TR224 because the lift is greater? I have an M6.
Old 04-04-2006, 05:59 PM
SHINER's Avatar
No, TR224 i believe makes more power becuase of it duration
Old 04-04-2006, 07:44 PM
jermzz's Avatar
http://www.ls1sounds.com
Old 04-04-2006, 07:51 PM
WS6RED2002TA's Avatar
Duration is only good to a point. Two valve heads respond well to more lift.
Old 04-04-2006, 07:53 PM
SideStep's Avatar
Actually it is not lsa that gives the lopey shakey idle..... Example... My new 226/230 112lsa cam has less lope then my old 232/236 114lsa cam. Is has to do with the overlap. My old cam had 55/6 degrees overlap and my new cam has 53/4, @ .006/.050 lift...
As far as power goes.... Street driven 346 LS1s "like" an intake valve closing between 43-46 degrees @ .050 and an IVO and EVC at equal distances from TDC...
Old 04-04-2006, 08:19 PM
bLkWdOw SS's Avatar
Ive done some research and the TR224 is looking good so far with my current setup. Cant wait till next month!
Old 04-04-2006, 08:28 PM
GR8GAME's Avatar
LS1Tech 10 Year
Ok so just to be sure cuz i'm a newb, a Comp Cam 224/224 .581 .581 will make more power than the TR224? Does the Comp come w/ a 114 LSA also? Gotta pass smog...
Old 04-04-2006, 08:45 PM
gollum's Avatar
Asuming your car is stock with headers, You need a custom grind cam. The one I listed below will develop lots of good street torque with a cool sounding idle (but no chills).
224/228 @.050, 108 lsa, 108 lc, .581 lift XE-R lobes
Much like Patrick's but with less lift.
Here:https://ls1tech.com/forums/generation-iii-internal-engine/481382-torque-coming-out-my-ears-cam-change.html
Old 04-04-2006, 09:27 PM
GR8GAME's Avatar
LS1Tech 10 Year
I'm going for the more stealthy sound rather than a lopey idle, but don't get me wrong I wanna make the power too.....and it needs to pass smog...Damn I jacked this thread big time lol
Old 04-04-2006, 09:43 PM
Thunder racing cheater cam or mti steath series 2. Thunder racing also has the cheater package heads and cam.
