Aftermarket heads WITH the TREX
What would be the best set of aftermarket heads to run with the TRex cam? What all will have to be done to the heads to make sure the PV clearance issues and all other issues are resolved before installing them. I'm not looking to spend 2k on a set of AFR heads either. Lets have the price range be 800-1500.
Also, would it be worth it to get a set of cheap stock heads and port them myself and then have the modified to work with the TREx and install them together? Thanks for the replies.
LS1 Tech Administrator
Best heads and $800-1500 don't belong in the same sentence. Maybe if you asked what would be the best heads for a 346 running a T-Rex under $1500? That would be better. The as-cast Dart 225s would be the first choice followed by the ported 243 heads by PRC and Livernois.
If you wanted the best (period), then it would be AFR small bore 225s or ETP 225 for your *****-out motor.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Well I only hope to see high 10s on my motor. Mods will be LS6 intake, lid, UD pulley, SLP headers, ORY, Trex cam, 4000 stall, and some sticky rubber most likely. Would the PRC LS6 CNC ported heads offered by TSP for 899 be good enough for that? That seems like a steal for brand new heads. What is the power difference seen between the AFR 225s and the heads I mentioned from TSP?
Getting high 10's is more than just making power, your gonna need some suspension, prolly a built tranny and maybe a rear ! I would go with some ported stock heads, and you will need flycutting Im sure with that monster cam !
LS1TECH Sponsor
I've been looking into flycutting, and you can do it yourself with the motor in the car.
Here are some directions, http://www.ffhp.net/tech_Isky.htm and search around the forum for "flycutting pistons" or "piston notching"
LS1TECH Sponsor
Yeah...
If I wasn't dead set on running an MTI setup I would be running PRC heads, here are some results
https://ls1tech.com/forums/dynamometer-results-comparisons/480312-holy-sh-t-prc-stage-1-dyno-results.html
