View Poll Results: Which of the cam/head options I have listed would you pick?
Option 1
30
12.93%
Option 2
25
10.78%
Option 3
32
13.79%
Option 4
27
11.64%
Option 5
29
12.50%
Option 6
89
38.36%
Voters: 232. You may not vote on this poll
Poll. MS3 with heads, or TREX with heads
Option 1: TREX/Dart 225cc package==$2200
Option 2: TREX/ PRC Stg 2 Dart CNC==$2400
Option 3: TREX/PRC LS6 CNC=======$1700
Option 4: MS3/Dart 225cc package===$2100
Option 5: MS3/PRC Stg 2 Dart CNC===$2000
Option 6: MS3/PRC LS6 CNC========$1600
These are some packages I put together by looking through some sponsors sites. This does not include gaskets, bolts, etc. Only the parts included in the TRex cam install package, the MS3 cam install package and whatever parts come with these heads. I already have a double roller timing chain but am unsure as to if I would need it with the MS3. I will also be getting an LS6 oil pump. I decided to find a head/cam setup instead of just installing the TRex by itself. That way, I get it all done at once. You all may even talk me into the MS3. Who knows? Here's the deal:
My car has an LS6 intake, lid, SLP LT headers, ORY, dumps, and a Fuddle 4000 w/tranny cooler as well. My car is a daily driver but I want to have an extremely potent daily driver. I'm looking to POSSIBLY dip into high 10s with some sticky tires and good launces. How it drives doesn't really matter as I have heard from MS3 and TRex owners that they are tame with a good tune. If not, I can handle it.
First off, is it possible with the combo's I had listed up there to touch 10.99? And if not, which is the most potent combo listed?
Second, how much money will it cost to machine the heads enough to work with the TRex? Anyone have any experience with this? And if so, what does it involve?
And Finally, which would you go with? Go ahead and vote in the poll, you all may persuade me to do something different =)
id not g0 the dart route form what ive read too many problems and i dot think youll have ptv clearence with a ms3 cam and dart heads
personally id do the ms3 prc ls6 head combo.. i think you might see a little more out of a trex ls6 combo if it would fit but theres no garentee and the t-rex is gnereally considered to be alot less streetable for only a few poneys at most espically in a auto car
i dont drive my car daily and dont know if id really wanna with a ms3/ prc package i think its more than enough cam for anyone
also if you go ms3 prc combo you get ti all from tsp and they can help you with any probs since its all their own ****
o yea if you still want more power then do a fast setup like im doing...
or if that wont do ti then id suggest saveing for afr heads and mill them along with adding g5x3 cam and fly cut the pistions.. this was suppose to make real good power but now your spending much more money
finally i can tell you that untuned thru a 3500 converter and a heavy drivetrain i did 400rwhp untuned
im thinking now that im all tuned up im probally rollin out 420rwhp unlocked or mabye close to 440-450 locked up
after i settle this whole fast swap im gonna retune and see what comes up .. personally im hopeing for 440 unlocked!!
I see a lot of you voting but no one posting their reasons why?! What would make you all choose what you are voting for? So far it looks like the Dart 225s with the TRex is the most popular choice.
How hard would it be to make this cam work with the Dart heads?
Would I just have to flycut the pistons and mill the the heads? If so, how much?
What are the problems with the Dart 225s that jpr5690 was talking about?
i had a problem with my prc darts pv clearence .... i sent them back and jason told me something was worng with the heads. He sent me a new set should be here this week or beging of next.... well see what happenes. They are spose to clear due to being same hight as stock heads but have bigger valves...
I've seen some dyno tests with the PRC LS6 heads and I think that's what I'm going to have to do. Still up in the air with the MS3 or Trex, but for costs sake, it will probably be the MS3 now. Anyone have some used PRC LS6 heads they wanna sell? Used MS3? PM me =)
LS1 Tech Administrator
You'll make more power under the curve with the T-Rex vs. the MS3 regardless of which heads you pick because the T-Rex has better valve events. Better dynamic compression and an intake valve closing point that puts more power under the curve and isn't so top-end biased. Don't get me wrong, the MS3 will punch an inpressive number above 6000 rpm, but if you're looking for the mid-range torque to go along with it, a narrower LSA cam like the T-Rex will put more "meat" under the entire curve, plus still squeak out a few more ponies upstairs.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Thanks for the info everyone! I had to go with the used Patriot 5.3 stage 2 heads from a member on here. At $625 shipped with head bolts, plus Gunnar's offer to reclean, check for cracks and leaks and fix anything wrong with them and install dual springs for another $275 shipped, I couldn't pass it up.
Now it's just time to pick the cam. I started another post about cam selection, but I am leaning towards the TRex before hearing anyone elses opinions.
What will I have to have done to this set of heads to make the TRex work? I know I will have to flycut the pistons, use new lifters (OEM or Comp R), LS6 oil pump and use a double roller timing chain, but will the heads have to be modified at all? Thanks for all the input!
We just made 429.9 rwhp unlocked auto with MS3 and a set of Nasty Performance heads 2.055 intake 2.02 exhaust $1750. Great cam sounds mean.
Forged 347
Nasty Heads
MS3 cam
Harland roller rockers
Stainless Works headers
LS6 intake ported stock TB
3200stall built 4L60E
3.73 12 bolt
Nate
Forged 347
Nasty Heads
MS3 cam
3.73 12 bolt
Nate
I would have to agree with Patrick here, i really didnt understand it but once i started to research and downloaded a VE calculator i could actuly see what exactly everyone was talking about. I think a big cam on a wide LSA is just a cheap way of trying to make it streetable, and makes the evo to early(ie loose power under the curve).
Justin
Well I'm off to work-will someone refer to my post in this thread 3 posts above this one about what is needed to make this cam work with these heads.
Also, I see the TRex cam install kit WITH dual springs comes with titanium retainers, hardened seats and new valve stem seals and the one with single springs does not have these parts. If I am getting new dual springs installed by Patriot are these parts usually included? If so, all I will need will be the lifters, pushrods and cam, gaskets, timing chain and LS6 oil pump? Thanks guys
