Pick a cam for a 2.73 geared, 3200 stall car
A buddy of mine wants a great cam matched up to his bolt ons/yank ss 3200/2.73 geared car. He wants to take the best advantage of his setup. I wanted to recommend a big cam but am afraid with his gearing and stall it'll fall flat in the low/midrange. Any cam experts out there that know better?
This is an a4 btw.
This is an a4 btw.
GO big or go home i say with that stall he should be good....get the ms3 or the t-rex or somthing big. get a set of ported heads if you can and other suporting mods like exhaust and the like. and you will be screaming
No you won't with such cams and those gears.
I recommend a 224/228, .581/.588 111+1
That cam will peak at 6200 (42 IVC), Great trq in midrange (46 EVO) and an equidistant
2* from TDC (IVO,EVC) will make it carry flatly to 6500 shifts.
4* positive overlap for a good lope.
the key is to maximize track performance without sacrificing highway mileage.
he already pulled a 13.001 at 107 without a tune or converter. i'm guessing he could knock off close to a full second with tires, the converter, cam and a tune.
Location: Your girl's back door giving her the long stroke while you're at work
I'm running the FM13 230"/232" .595"/.585" 114LSA with a TCI 3000 stall and 2.73s. I knocked off almost 1.5 seconds off my time ( 1.4 to be exact). The 2.73s are killing my trans and converter so I'm going with 3.42 in a couple of weeks. Goodluck
killing your trans and tc ??
can you elaborate on this please
Will update with times next week, but last run with 2.73's car ran 13.9. Car should run between 12.8-13.3 with the few mods ive done since.
Originally Posted by jlashley2001ss
any ways to prevent hurting the tranny?
why not go with a 110+0 LSA on this? this is what im thinkin bout w/ my 3.23 gears.
224/228,110LSA/110ICL
2>IVO
42>IVC(peak 6200rpm)
44>EVO(Great low-mid trq)
4>EVC
110>ECL
6>Overlap(more lope)
This cam will be a tad more peaky and will carry (later EVC relative to IVO from TDC)
Catch it early if you think something is wrong. If the car isn't a daily driver then go with a TH400 but if it is then instead of rebuilding when that time comes go with one from Rock-On or FLT. Search around here Automatic Transmission for more info.
my car is not a daily driver. but it does get driven, enough, i guess you could say.
how many miles do you think you drove when you started seeing this problem ??
It's jacked up again and I am going to drive it until the trans lets loose. I've got about 3000 miles on it since the rebuild and it is going to Ohio in a week so when I order the new one this one will have about 5K on it
Im actually having a F13 112lsa and heads installed with a yank ss3600 stall in my c5 a4 with 2:73 gears. Its only for a few months untill i get the 3:73s or maybe 3:90 gears, but untill then i think it will be fine. just make sure you install a tranny cooler.
