max bore on a 6.0 iron block
Old 07-05-2006, 04:28 AM
bumpin_records's Avatar
Default max bore on a 6.0 iron block
How far can u go with boring a 6.0 iron block?
Old 07-05-2006, 04:40 AM
Nate_Taufer's Avatar
4.03 is normal, 4.06 is good only with a sonic check. I have seen one company make a 4.08" iron block but that was probably pretty rare that is sonic checked good.
I would just go 4.03" and leave plenty of meat on the walls if you're going to make any serious power.
Nate
Old 07-05-2006, 08:14 AM
Demon SS's Avatar
as stated max is around .060 over if the block sonic checks good; and as also stated .030 over is the norm, if you wanted something differnt do a .040 or .050. it does not really get you much but you would be a little different.
Old 07-05-2006, 04:26 PM
ArcticZ28's Avatar
I wouldn't go too crazy with the bore on a 6.0, 4.030 is a pretty good compromise. You never know when you're gonna need a hone or cleanup on the cylinders because of some stupid crap or accident internally.
Old 07-08-2006, 09:59 PM
so tell me this, stock crank X 6.100 rod X 4.030 bore = WHAT?
also what do you think about these rods
http://cgi.ebay.com/ebaymotors/New-4...spagenameZWD1V
or
http://cgi.ebay.com/ebaymotors/Ultra...spagenameZWD1V
I will be using arp L19 rod bolts with the rods, oh yeah turbochared
just to let you know im looking for like 800+ hp " low 9's" is it possible with these rods
Old 07-09-2006, 12:05 AM
BIG BAD BLACKSS's Avatar
Stock crank and 4.030 bore = 370 cubes
Old 07-09-2006, 12:18 AM
blackbelt's Avatar
Mine is 4.080
Old 07-09-2006, 12:39 AM
Originally Posted by blackbelt
Mine is 4.080
dayum 4.080 man how are you holding up? how much horse power are you running
Old 07-09-2006, 12:41 AM
so what about the rods what do you all think about them
Old 07-09-2006, 04:20 AM
Honestly cant recommend anything as i dont know LS1's that well yet im still too much of a newb to recommend anything, but i know a 4.030 bore and the stock crank is a 370. Ive thought about building that combo. Rod length wont effect the cubes at all. The different lengths can help with taking pressure off the cylinder walls some /(longer rods) but there is another downside to it that im forgetting right now. Theres alotta threads about the connecting rod length debate.
Old 07-09-2006, 10:26 AM
ArcticZ28's Avatar
If I were you, I'd go with Eagle or Lunati rods. I wouldn't buy crap/no-name stuff off of ebay.
Old 07-09-2006, 11:08 PM
well im gonna go with eagle then
Old 07-09-2006, 11:34 PM
RomulusSmallBlock's Avatar
i don't think the .06 rule applies to the Gen 3 engines at all. i did my 5.3 L .120 over with no problems at all. the walls are pretty thick still as in i could have done way more. i would say its the machine shop guy and your call. the iron block gen 3 have walls that are thick almost syammised, but with 4.40" bore spacing and a bore of 4"...you do the math
Old 07-09-2006, 11:36 PM
ArcticZ28's Avatar
Not the case, for example, with LS1's as they can only be bored over about .010. The LQ9 block can only be bored .060 safely with a sonic test to make absolutely sure it is fine. Anything more than that is not safe and would require sleeving.
Old 07-10-2006, 11:59 PM
i guess i should have mentioned non-aluminum engines.
Old 08-30-2006, 10:39 PM
shaulinmathvader's Avatar
So I am guessing a maybe 12.0:1 compression motor bored over .1 to a bore of 4.1" w/ maybe a 100 shot is out of the question?
Old 08-30-2006, 11:01 PM
ArcticZ28's Avatar
The only way to safely achieve anything higher than a 4.060 bore is to have the block sleeved.
Quick Reply: max bore on a 6.0 iron block
