Need input on tools for degreeing a cam
What kit or tool setup are you guys using when degreeing in a cam on a ls1?
I have a few wheels here but and in the air as to what is used as a crank socket for the degree wheel to attach to. Any input would be greatly appreciated. Thanks again guys and sorry for the newbie questions.
Elec
Elec
LS1 Tech Administrator
You'll need a piston stop to determine TDC.
A spacer to position your degree wheel out to where it's not hitting the block. A hollow socket can work in a pinch. Use the crank bolt that holds the balancer on.
The Degree wheel.
A rod to be used as a pointer (welding rod will work in a pinch).
A gauge mounted on a pedestal that can be secured to the head or a body panel that won't move. You'll want it to measure off the pushrod or rocker arm.
The Degree wheel.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
