Patriot stge II head owners(243 castings)
What are some of the largest cams are you guys clearing with.....2.02/1.57 valved heads......no milling or milled...thanks
Well I have the 243's from Patriot so I'll chime in. Specs:
milled .010
.045 gasket
Ferrea 2.02 and 1.57
Thunder Racing 224/224 on 114 with 4* of advance
I remeasured my intake clearance the other day and came to .080 (about 1000 miles after head install) on the closest cylinder on the driver side while the opposite one a few weeks prior got me .130 (right after head install). I'm not sure why it varied so much. I had a bit of room to breathe on the exhaust side. I want to say that clearance came to be about .130. I'm not 100% sure on that though. With my setup, I don't think I'd feel comfortable with anymore than a 224/228 duration cam based on my measurements. With some aftermarket valves you have to be careful of the margin also. This was my pitvall. I didn't realize some of them were much more than stock, thus giving up a good deal of PTV clearance. Here's a pic of what I'm talking about.
stock on the right and ferrea on the left.
milled .010
.045 gasket
Originally Posted by TWISTEDTA
well, i went with the F11 to play it safe
That is exactly what i wanted to hear....im almost 99.99% sure im goin with an F11 cam myself. Just wanted to see who else is using it
What tools did you use that cost 150.00 if you dont mind me asking? Im so aggrevated right now bout all this... Its like if i would have known that ptv was such a problem with this Ferrea valves(more than one person has told me about issues) i would have left the 2.00/1.55 valves in and had cam options out the *** Only reason i chose F11 is because Allan Futral, and Gunnar both said it will fit fine, but any larger(TSP V2,F13,etc) would be getting too close.....makes me sick to have a nice flowing set of heads but have to run such a small cam Thanks for looking out for me though buddy
Oh yeah and you said milled too.....was your heads milled any. Mine are unmilled so would that make a difference
I hear ya Kazfan, I'm with ya on that. To check PTV clearance check this out: https://ls1tech.com/forums/showpost....64&postcount=6
This is what I bought and it's about the best u can get.
http://store.summitracing.com/partde...5&autoview=sku
You'll need to make part of the stand from the previous url to get that kit to work. It's the only one out there that I know of though. It's easy to make with two bolts, a nut and some kinda strong epoxy like JB Weld.
Having unmilled heads makes a HUGE difference. You'll probably want to mill them for higher compression though. You'll be leaving a lot of power on the table with near stock compression.
Mine were only milled .010 btw. Looking back on it I wish I milled more because there is a lot of power to be gained by bumping up the compression. I think it was someone from TEA that did an interesting study showing that a stock 241 casting ported head milled for high compression made more power than a near stock compression aftermarket high dollar head. If the aftermarket head was milled to the same cc's, everyone know's which head would make more power though.
Here's the thread:
https://ls1tech.com/forums/generation-iii-internal-engine/528602-massive-dyno-testing-session-revealed.html
Here's the thread:
Hmm....just curious but would 5.3 heads with same valve sizes have similar issues. I'm asking b/c I'm running 2.02/1.57 manley valves in mine and wanting to jump up to a slightly bigger cam. As of now I have no clearance issues but want to know how far I can push it. Heads are not milled either and cam is in sig.
I really dont think the valve diameter is the problem.....not sure bout manley valves, but the Ferrea's as pictured above sit .040 deeper into the chamber=less clearance.
