How much should oil pressure drop from cold to hot?
Old 07-18-2006, 10:07 AM
Boostaholic's Avatar
Default How much should oil pressure drop from cold to hot?
Startup is about 45, full hot (overheating) is 30
Old 07-18-2006, 11:35 AM
PREDATOR-Z's Avatar
That varies on weight of oil and whether it is synth or not.
Old 07-18-2006, 12:36 PM
not synth 10w30
Old 07-18-2006, 05:30 PM
John02SS's Avatar
That is about what I've seen with non syn oil. I see about 45-50 at normal temps and 30-35 ish after it is really hot and has been beat on. After I get a few more miles on it I'll go back to Redline 10w40 like I ran in the other motor. No issues with it dropping too much when it gets hot.
Old 07-18-2006, 09:01 PM
That redline 10w40 is a full synth?
I've been thinking about getting that melling ls1 high volume / high pressure oil pump from thunder.
http://www.thunderracing.com/catalog...&vid=3&pcid=83
Or if that isn't quite the ticket I can afford a dry sump, it will just take me a little while to save for it. I've always wanted one, just never _needed_ it. But it makes me real nervious when the oil pressure gets under 35-40
Old 07-18-2006, 09:55 PM
ArcticZ28's Avatar
35-40 is plenty at idle, even 30 is perfectly fine, unless we're talking that reading is at WOT, *then* that is something to worry about.
Old 07-18-2006, 11:38 PM
I'm just talking about idle / idling down the road. Have not even made a WOT run recently, need to make sure everything else is fine before WOT runs, then I'll throw new turbos back on the car and be in business.
Old 07-24-2006, 10:22 PM
John02SS's Avatar
Redline is a full syn. Your pressure is good though, I wouldn't worry about as long as it builds on RPM when your in it.
