Ordered my custom cam today...
Old 07-20-2006, 04:44 PM
8banger's Avatar
Default Ordered my custom cam today...
Hey everyone....after realizing that .650" lift kind of worries me in a daily driver, I decided to tone it down some (well, lift-wise anyway) and order a custom ground cam that wouldn't beat the hell out of my valvetrain quite so badly. After much deliberating, calculating, playing with valve events and DCR, etc., I came up with my profile. I'm on stock heads until...well, I don't know when, until I find a good enough deal. I have every bolt-on except for an underdrive pulley and electric water pump (maybe someday). No cats, relatively free-flowing exhaust, 3800 stall, 3.73 gears, full suspension (minus cage), good tires, and about 250# of weight reduction. I was looking for a cam that wasn't as wicked lift-wise as the TRak, easier to tune, and while not radically different than what's out there, a little bit different than most cams. I wanted something that had a noticeable idle, smooth, well-distributed power band, nice top end, and good DCR. I'm hoping to run low 11's cam-only, and I see it as entirely possible. I may spray even though this is not a spray cam. I won't say exactly what the specs are until it's all installed and said and done, but think about it as being basically one of the G5X cams on a tighter LSA. Streetable, yet powerful and intimidating. Wish me the best...I've always wanted to grind my own design and here we are. Results will follow soon.
Adam
Old 07-20-2006, 05:04 PM
Fratsit's Avatar
Definately sounds like you put quite a bit of research into this project. I hope it works out to your satisfaction.
I'll keep an eye out for your results. I am really interested in your cam specs.
I decided to go with an off the shelf grind from TSP (Torquer V.3) for my first cam swap.
Look forward to those results.
R/
Frat
Old 07-20-2006, 05:06 PM
ringram's Avatar
Thread is worthless without specs
Old 07-20-2006, 05:59 PM
LS1 Tech Administrator
Patrick G's Avatar
Good idea on going with the narrower LSA, but unless you're selling the cams in the future, you should really consider sharing your specs. This board benefits when we see what works and what doesn't.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 07-20-2006, 06:38 PM
ninobrn99's Avatar
Adam is worse than a woman and clothes when it comes to cams! man i hope you like this one...at least for more than a month
Old 07-20-2006, 06:42 PM
8banger's Avatar
Honestly, Patrick, you were my inspiration in going for a narrower LSA. The TRak just wasn't for me, as I need something a little lower lift. I'm sure I'm just being paranoid, but hey, it's my car so it's subject to my idiosyncracies. I guess I can reveal the specs, if it works like I hope, awesome...if not, there's no shame in going for it. So here's what it is: Comp XE-R lobes (I know everyone has them, but for the size cam I want, LSK's are just too high lift, plus tuning is so easy with XE-R cams now), 234/242, around .600"/.610" lift, and a 110 LSA. I was struggling with the idea of the low LSA and relatively large duration, and its effect on my idle quality, but the thoughts of a wider powerband, potential higher peak, better DCR, and the idea of something a little different swayed me. Plus, I thought about the G5X4, T-Rex, and similar cams and how streetable they can be....and I'll have one of the best tuners working with my car, so it should be good. I can't wait to get the cam and see how it runs, then add some heads to it.
Old 07-20-2006, 06:43 PM
8banger's Avatar
Yeah...I may be indecisive, but who taught you about 370's?
Old 07-20-2006, 06:46 PM
ninobrn99's Avatar
HEY!! HEY!! easy with that guy Ill admit, it was you Any idea what your DCR will end up being? I need to work on a cam for mine, but need to get the heads done first.
Old 07-20-2006, 11:03 PM
8banger's Avatar
DCR is a little over 8.0. SCR is 10.4:1
Old 07-20-2006, 11:08 PM
ninobrn99's Avatar
not too bad...have you played around to see what the dcr will be with a smaller CC?
Old 07-20-2006, 11:12 PM
Super Hulk Smash
JakeFusion's Avatar
If you want that cam to purr, go with a speed density tune. It'll tame it down quite nicely if you are at all concerned about the overlap.
Old 07-20-2006, 11:54 PM
8banger's Avatar
I'm thinking about it...I may have access to it.
Nino, I haven't just yet....if I get sidetracked, the car won't run any time soon...haha.
Old 07-21-2006, 12:08 AM
ninobrn99's Avatar
about the tune, either one is fine. it all depends on what your tuner is good at and comfortable with as well as how much time he has to dedicate to the tune and how much money you have
Old 07-21-2006, 10:22 AM
Patrick G's Avatar
That cam sounds excellent. How much advance are you getting ground in?
__________________
Old 07-21-2006, 11:19 AM
8banger's Avatar
I'm getting in as a 110+2.
Thanks BTW, I feel honored. I'm just trying to make the best of an XE-R lobe.
Old 07-21-2006, 11:27 AM
Ωmega's Avatar
Bish, check your PMs
Old 07-21-2006, 11:28 AM
Patrick G's Avatar
Those valve events will be PERFECT. You have learned well young grasshopper. We look forward to your strong results!
__________________
Old 07-21-2006, 11:39 AM
ringram's Avatar
You can even run alpha-n fueling if its very lumpy, some guys with jumpy cams have had good results with efilive custom os5's implementation of it. Should sound nice and angry anyway.
8banger's Avatar
Hopefully it will pan out well. What would you recommend for heads? I wouldn't mind AFR's, but they are money. I was thinking about Darts as well. What should I look for in the right heads for this cam?
