What are the best heads for a ls6?
Old 07-30-2006, 04:55 PM
nightmarevette's Avatar
Default What are the best heads for a ls6?
Yeah I have a 02 Z06 with a magic stick 3 cam. I want to get the best possible hp/tq out of my setup. What heads would give me the most gains? I do not plan on going blower/turbo route. I want to be all n/a. Money is not a object here.
Old 07-30-2006, 05:19 PM
Old 07-30-2006, 06:28 PM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
Money not an object???
Well, If I had that luxury I would go with ETP 215 heads on a stock displacement motor. Contact Andy at A&A Corvette and ask him about these heads. He had great results with them on a stock displacement LSX motor.
AFR 205cc are also very popular, very pricey, and very well made. Consistent results and lots of users so you can search the dyno section for their results.
Good Luck.
Old 07-30-2006, 07:33 PM
what about the texas speeds, terminator heads? How do those compare to the et's and afr's?
Old 07-30-2006, 08:14 PM
sickss228's Avatar
Check out Cartek for the best heads. The currently hold the record for the highest RWHP from a stock bottom end at 507.9 RWHP, this was done with a cam that is smaller than the MS3 and T-REX which is a testament to their killer heads.
Old 07-30-2006, 08:17 PM
will82's Avatar
Impressive!
Old 07-30-2006, 10:02 PM
RoastEmSS's Avatar
AFR 205cc seems to be the dominant head lately, if money was no object, id def get them
Old 07-31-2006, 09:24 AM
Brian Tooley Racing's Avatar
The two most powerful heads for a stock block, 3.90 bore Z06, is the ET 215 and the TFS 215. The TFS do not require the optional rocker stands or relocating your alternator. Both also have more piston to valve clearance then your stock heads.
Old 07-31-2006, 11:21 AM
So if I want to get the most hp/tq out of a set of heads I should go with the et 215's? What gaskets should I go with also?
Old 07-31-2006, 06:17 PM
Old 07-31-2006, 07:06 PM
HOSS's Avatar
afr 205's hands down
