Injectors for TF heads and fairly large cam?
Old 08-01-2006, 10:41 AM
jermstyle's Avatar
Default Injectors for TF heads and fairly large cam?
I知 still have the stock injectors in my 02 LS1 and I知 curious if I will need high volume injectors to handle TEA Trick Flow heads and a 232 or 237ish cam.
I will also be spraying a 150 wet shot.
The fuel system is in place to support this already (racetronix).
Thanks!
Old 08-01-2006, 11:00 AM
PREDATOR-Z's Avatar
30lbs SVO will handle that but 42's would be better.
Old 08-01-2006, 11:04 AM
Tom@SpeedInc's Avatar
+1 for SVO30s
Trick Flow vavle springs only good for .600 lift......... WTF? might as well just buy TEA TF heads with dual springs.
Old 08-01-2006, 11:09 AM
jermstyle's Avatar
What?
SVO?
What about Racetronix #42's - Are SVO's the best?
Old 08-01-2006, 11:23 AM
PREDATOR-Z's Avatar
SVO are Ford (Bosh) 30 lbs/hr (rate ~ 36lbs/hrs on our system)
There is many 42lbs injectors, Lucas being one of my favorites.
Old 08-01-2006, 01:59 PM
jermstyle's Avatar
Thanks for the help guys - looks like I'm going with SVO 42's...
Old 08-01-2006, 02:37 PM
exSSer's Avatar
+1 for SVO30s
They're rated for .650 lift.
I went with 36.5 Racetronic injectors with a 228/232 cam, but I don't plan on spraying it.
Old 08-01-2006, 03:23 PM
2000blackta's Avatar
I went with SVO 30's with my setup.
