Just Installed Ms4
Just Installed Ms4
Stock 98 M6 With New Ms4 Cam Pack, Asp Pully,k&n Filter Sounds Like It Has A 224 Cam.hope To See How Well It Runs At The Track. I Bet No One Has Tryed It With Stock Pipes And No Cut Out.
Originally Posted by FOXYHAWK01
Track First Then Possible Dyno I Live About 7 Miles From Bristol Dragway
I was there Tuesday
Originally Posted by eamador11
I highly doubt that. bet it shakes the coffee cup off your dash. lmao
Originally Posted by Irocss85
fad2blk, why did you replace the tsp cam you had? Im not famaliar with the MS cams. who sells those? do the pistons need to be notched for valve clearance?
cool car, you should check out the pics of my dads MECHAM on my yahoophoto account.
My best friends wife has a MECHAM TA also.
Originally Posted by Fad2blk_98
It doesn't sound like any 224 that's for sure, but there isn't much vibration inside. I just installed mine this last weekend and will have sound clips and dyno numbers soon.
BTW, nice ride you got there.
Might end up getting that, but not sure. I haven't had a chance to drive it around much to see how driveablitly is, but I didn't have any problems with the 233/239 I had in there before either.
Thx for the comment on the car.
The MS4 cam is still a TSP cam. I changed because I was getting a set of heads and wanted a good combo. I was tearing apart the motor anyway, so went with the MS4 cam with the LS6 Stg1 heads. The pistons are fine with the stg 1, but need cut for stg2 from what I've read on here.
yeah I figured that out MS= magic stick4. duh. so then the stage 2 heads are milled and the stage one heads are not? so if no milling of the heads and stock head gaskets on an 02 and no flycutting? Id like to get the most aggressive cam I can get for an M6 car that doesnt need flycutting.
and, can you get me some pics of your buddy's wife's mecham? Im collecting all the pics I can on mecham cars. thanks
on another note, how did you black out your taillights? I did the same thing to dads car with nightshade paint, wetsanded, polished, clearcoated, wetsanded. and repainted the center filler black. looks like the rest of the cars paint. it looks kickass. were leaving his all black. was goin to do the silver bird, but decided it looks too mean all black.
