View Poll Results: H/C SETUP
Voters: 28. You may not vote on this poll
H/C options narrowed, what should I go with?
So I have put a lot fo research into this and hope to have the sawp done with a month and a half, or less dependign on the wait for parts. I am wondering which setup will be the best for a DD car that I am trying to boost power on but keep very tame/streetable. Want it to have a unstock sound, keep the TQ high and if anyone has any ideas on the HP/TQ numbers the setups may make that would be helpfull aswell
CURRENT PERFORMANCE MODS...
Engine:
-T-Rex cam (COMING OUT FOR NEW CAM SETUP)
-Patriot Gold dual spring kit(WILL BE ON NEW HEADS)
-Thunder Racing heat treated chrome-moly pushrods
-Rollmaster heat treated adjustable double roller timing set
-Stealth airlid w/ K&N filter
-Thunder Racing billet MAF ends, black
-Jantzer ported and black powdercoated throttle body
-LS6 intake manifold
-March underdrive pulley
-ARP Pro Series rod bolts
-Ported LS6 oil pump
-Prothane poly motor mounts
Exhaust:
-Edelbrock Victor Series drag headers: 1 3/4" to 1 7/8" stepped long tubes with merge collectors and off-road y-pipe
-Hooker cat-back
Rearend:
-Driveline Solutions Ford 9" - 4.56's, Detroit TrueTrac, 31 spline axles, Strange SS case, Daytona pinion support, 1350 yoke, solid pinion spacer. 1/2" x 3" screw-in wheels studs
Engine:
Exhaust:
-Hooker cat-back
Rearend:
want something i can shift below 2k RPM's with and, really want more low end torque, I bought the car with it in their and just didn't really take to it except for the sound, i love the sound.
