crack lines in valley cover - would you guys use this?
Old 08-30-2006, 12:35 PM
FastKat's Avatar
Default crack lines in valley cover - would you guys use this?
I bought this off of a board member and was a little surprised when I opened it up. I don't think valley covers "wear" so I didn't really push the condition of the part... however now I am wishing I would have asked more questions. It looks like there are little crack lines over parts of the surface. Would you guys use this LS6 valley cover? Is this normal?
Thanks, -Dave
Old 08-30-2006, 12:38 PM
JMBLOWNWS6's Avatar
Normal casting cracks. When I cleaned up alot of my parts with the bead blaster they looked the same.
Old 08-30-2006, 12:39 PM
muncie21's Avatar
Looks like casting marks. I wouldn't be worried.
Old 08-30-2006, 12:48 PM
FastKat's Avatar
So if they were casting marks... I could probably polish them out, right? Not saying I want a polished valley cover, but just to make sure they're casting marks.
Old 08-30-2006, 12:49 PM
muncie21's Avatar
why bother? It's a cover, it doesn't really seal anything.
Old 08-30-2006, 12:50 PM
bmfcamaro's Avatar
my was like that. that is the way those parts look. the thermostat housing is the same.
Old 08-30-2006, 01:09 PM
FastKat's Avatar
I am doing a turbo setup and am wondering if presurizing the engine block (from blow-by) will cause an issue. I don't want any crap falling down off of the valley cover into the oil pan if it does to start to come apart.
I think the valley cover does seal the top of the block, helping to maintain vacuum, doesn't it?
Thanks for the input though... I am going to take another good look at the valley cover tonight to see if those lines are casting marks.
Old 08-30-2006, 01:23 PM
PREDATOR-Z's Avatar
Yeah that is normal, but if in doubt, take it to a machine shop and magnaflux them. That will tell you if they are indeed cracks.
Old 08-30-2006, 03:28 PM
GuitsBoy's Avatar
Do they go all the way through to the other side?
FWIW, every LSx cover ive ever seen has those casting lines.
Old 08-30-2006, 04:16 PM
oange ss's Avatar
if you have that much blowby you might want to consider a rebuild
yes it does, to seal the engine for the PVC system
Old 08-30-2006, 05:24 PM
67Firebird455's Avatar
Wish you could magnaflux aluminum.
Old 08-30-2006, 05:39 PM
FastKat's Avatar
I have a forged HPE shortblock and I'm not up and running yet... I'm going to be PISSED if I need a rebuild on a brand new engine!
Old 08-30-2006, 06:01 PM
LS1-IROC's Avatar
Those are completely normal...I used to work for the die-casting company that made those covers.
Old 08-30-2006, 06:08 PM
LsReddog's Avatar
Magnaflux doesent work on non-ferrous metals. Those arent cracks just part of the casting.
Old 08-30-2006, 06:15 PM
ls1408cp's Avatar
here is a pic of mine i polished it and it had the same casting marks
Old 08-30-2006, 06:42 PM
LsReddog's Avatar
That looks like some badass stuff goin in there What heads (look like ET) and rockers you got there?
Old 08-31-2006, 03:52 AM
PREDATOR-Z's Avatar
Isn't there another method using UV reflective die? maybe magnaflux is not the right term.
Old 08-31-2006, 04:20 AM
LS1-IROC's Avatar
Zyglo is the only one I am familiar with.
Old 08-31-2006, 04:22 AM
LsReddog's Avatar
I believe its called Zyglo its a dye type.
Old 08-31-2006, 04:53 AM
OldSchoolFormula's Avatar
LS1-IROC, just was impressed witrh the car and wanted to say... NICE.
