Forged 347 or stroker:374, 383, 402, 408, or bigger Aluminum or Iron Block
I just spent quite a bit on my rebuilding my top end.
COMP 228/236 575/590 112 lsa CAM AND LIFTERS, ONE PIECE PUSHRODS 7.100, PATRIOT 1.7 ADJ ROLLER ROCKERS, AND DOUBLE ROLLER TIMING CHAIN. STAGE 3 PORTED AND POLISHED 806 HEADS WITH MANLEY STAINLESS 2.02/1.60 VALVES COMP SPRINGS AND TT RETAINERS.
Now that i cant drive it because i spun a bearing im needing to upgrade the bottom end. spending more money.
So the question is what should be done. forged 347 bottom end or go all out and stroke it. if thats the answer how far should i go: 374, 383, 402, 408----427.
give me some help and some tips guys for a good build bottom end build. what crank, rods pistons, and what block aluminum or iron.
i need some expirience here. thanks for the help
im also panning on using the top end internals/valvetrain i have.
Its all depending how much power and what u want to spend. I started my 347 build up for my track car. So far Im 900 dollars in it. Texas speed has a good deal on piston and rods. All motor Im looking for 450+ with a six speed and prc heads and ms4. Then Im going to spray it. The stock crank is good to 1k i have read. So with block honing and assembly, and berings u shoud be around 2k I purchase all my bering from car quest the whole bering kit cost 150 dollars. Just about how much do you want to spend and how big? If you stay na I say go big 408 or 402 more tq than a 383+ I think sleeeving cost bukoo dollars better of buying a short block
well im not looking to spend a whole lot. kind of a budget build up since i just blew quite a bit on my top end. but im prolly gonna get a know block considersing some of my head bolt holes had been stripped. thanks for all the input already.
Originally Posted by ssam98
If you use your ls1 block you could go 383 or 395. If you resleve it go 427. If you go ls2 go 402 not 408 iron block to much of a load for the car to move around.
I love the statements on the iron block, so from your statement the LT1 can't move, neither can any other sbc, or the cobra with the iron block.
You would be very surprised to see how well a 374 runs.(3.9 stroke and 3.905 bore) I have built both 383's and 374's and prefer the 374 over the 383. Eagle has the rotating assemblies for this application for a resonable price. Of course if you want to spend more money than the 402 is the way to go.
so exactly how big could you go with an ls2 aluminum block. so if i did go any bigger than a 383 what exactly would i need as far as heads and valves compared to what im running now. and the 408 or 402 would my ls1 full length headers bolt up cause i just invested in a new set. thanks again everyone.
s so if i did go any bigger than a 383 what exactly would i need as far as heads and valves compared to what im running now. and the 408 or 402 would my ls1 full length headers bolt up cause i just invested in a new set. thanks again everyone.
sounds good to me. so what all would be involved on making a 383 ls1. i know they are sleeved, so can they be bored. thats what i was unsure about. would any other machining be required as far as crank and rod to block clearences. in not real intuned to the ls1, sorry if some of these questions are alittle stupid but i would not like to make a thousand doller mistake or two. thanks for the info thus far.
and what would be the the best way to go on building a solid higher rpm 383 without breaking the bank.
A 383 with an ls1 block is 3.905 bore/ 4.00 stroke. If he uses a 4.125 stroke he will have 395 cu.in. Eagle doesn't stock a 4.125 stroke. They stock 3.9, 4.0, 4.1 stroke.
Tin Foil Hat Wearin' Fool
I think it is really funny those who think the 60# difference in blocks will relly make the handling that much worse. When your 200# friend is sitting in the passenger seat is your handling/braking really affected. No.
383 is the way to go with a mid 230 cam, 400+ CI motors like big heads and big cams. Minimum for a big stroker is going to be 2.02 valves with 225intake runners and alow 240* cam IMO. Im running a 237/242 112 cam in my 418 and it has too much tq even for my 4wd truck, I will upgrading ot a 245/250 113 cam soon.
i think you should do a 402 ls2 or a 408. unless you can afford the price of a 427. later down the road you will want something bigger then a 347. plus you will get a 4" bore instead of the 3.9.
ok now. the heads i have are stage 3 ported and polished 806 heads by brannon performance with the oversized valves manley 2.02/1.60. if i did go bigger than a 383 with my block like the 395 what could i do with the heads to complement it. and again would the cam i have really compliment either a 383 or a 395 or would it be best to invest since its apart. i would just have to replace these parts since i had just imvested in them and the only have 90 or 100 miles on them, thats why i really would like to go as big as i can without having to rebuy. thats so far guys.
