98 Z28 with 02' engine Help
I am going tring to get my parted 98 Z28 Turbo project back to running condition with a stock 2002 drivetrain.
I bought an 02'engine and tranny combo complete to put back in my 98 Z28. I was planning to repin my engine wiring harness so I could use te 02 PCM's capability to have RTT with HPTuners. I have since changed my mind and am going to use the factory 98PCM harness. I dont want to mess with all the rewiring right now.
My question:
-What changes are needed to run this 02 engine with the 98 harness sensor wise?
-What sensors have to be swapped out to work with the 98?
I want to cover my bases before I dive into putting this car back together. The fewer suprises along the way the better.
Thanks for any help. It is appreciated.
My question:
I am going to use my 98 PCM and harness. I think I have to change out a couple of the 02 engines sensors to work with the 98 harness. I think the knock sensrs are different, and the temp sending unit may be different. I just want to be sure.
There was a thread on efilive.com about a few guys rewiring the 98 and 99+ harnesses even using them on LT1's etc. Take a look there http://forum.efilive.com
