do i need new rocker arms?
Old 09-11-2006, 08:35 PM
RooRnZ28's Avatar
Default do i need new rocker arms?
hey all
i'm in the middle of my camswap andd.....i have hardened pushrods and dual springs installed. now do i need new rocker arms or will the stock ones be ok for awhile? after my camswap i'm gonna be slapping on an sts kit, so will the stocks last or do they need to be upgraded? thanks
Old 09-11-2006, 11:39 PM
shanev8's Avatar
stock will last till u get around .650 lift...
im not sure but i know i had a big cam with stock rockers and nothing bad happend, people go 9's with stock ones also...
Old 09-12-2006, 02:33 PM
RooRnZ28's Avatar
even with hardened pushrods and dual springs will they still be ok? it just seems like the rockers are the next weakest thing that would break... i wont be spinning the motor past 6500 rpms, as i'm just putting a baby turbo cam in... i just want to be sure everything will be ok
Old 09-12-2006, 03:20 PM
Black Sunshine/ 00SS's Avatar
Yes, they will be fine..
Old 09-12-2006, 07:13 PM
redtail2426's Avatar
the stockers will be fine....if your nervous just send you stock rockers to harland sharp for a rebuild using a different bearing setup..and thats all you could ever need really.
Old 09-12-2006, 07:16 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Don't forget Nasty Performance too. They can rebuild stockers. only around 250$ VS. a new set for 500+.
Old 09-27-2006, 12:54 AM
ZL1Killa's Avatar
i will be looking into that. thanks for the info guys. yes i know i just popped in; but been looking at this the past few days
Old 09-27-2006, 12:09 PM
Dbl.0.Five's Avatar
When you talk to Nate ask him about the Curtisbilt rockers I think there at racecurtisbilt.com
Old 09-27-2006, 02:19 PM
dedge's Avatar
Your rockers will be fine. The same company that made your rockers make the 1.85 rockers that SLP sells and you got to look close to see the difference.
Quick Reply: do i need new rocker arms?
