What Should I See On The Dyno 408!
Well I Have A Iron Block 408 Stroker. Mahle Rods. Mahle Pistons. Callies Magnum Crank. Custom Grind Crower Cam. 237/245/587-592-114lsa. Lq9 Heads.ported Hivolume Ported Oil Pump. Ls6 Wieand Lingenfelter Polished Intake Manifold. Jethot Longtube Headers. Slp Y Pipe. Slp Loudmouth1 Catback. I Had This Motor Turbo/blower Ready. 8.8 Compression. I Ran Out Of Money For The Turbo. So What Numbers Should I See On The Dyno? Please Help! Thx!
You may be in that ballpark... CarolinaWS6 made that power through an automatic. I'd say you'd be sitting a little below what he made because he has a little more compression and a little better flowing exhaust, and a Fast 90/90, but nonetheless, you will be making good power. Is your car a M6 or A4?
