Prc heads and a 228R install finished
Old 09-15-2006, 07:08 PM
Rothman's Avatar
Default Prc heads and a 228R install finished (vid)
Well Finally finished installing my heads cam and intake today. I couldn't have smiled harder when I fired it up the first time. It's a little choppy and needs a tune but all is in good working order. The install was made easy with the ls1howto.com reference page. I'll have a vid in a few minutes.
Old 09-15-2006, 07:13 PM
ls1z01's Avatar
NICE .. get it dyno tuned and let us know how it did!
Old 09-15-2006, 07:15 PM
WhiteStripes's Avatar
Wish we could say the same about the last H/C install we did. But congrats, now let's see you melt those tires.
Old 09-15-2006, 07:18 PM
Rothman's Avatar
no tire melting just yet, I'm going too let the new valve springs cool overnight. We'll see what happens tommorrow though. Working on getting the vid up right now. It's just a quick idle clip. Probably have a few more to post tommorrow.
What happened with your install?
Old 09-15-2006, 07:26 PM
Rothman's Avatar
http://s78.photobucket.com/albums/j1...nt=Picture.flv
There's the vid. Like I said just a quick untuned idle clip. More to come later!
Old 09-15-2006, 07:35 PM
Trunion King
bene's Avatar
Sounds really wicked. When are you going to run it?
Old 09-15-2006, 08:30 PM
Rothman's Avatar
Thanks man. Not sure when I'm going to run it yet. Really depends when I can get it tuned and even then I'll probably baby it for a while. Stock clutch and rear
Old 09-16-2006, 10:03 AM
99zman's Avatar
wow that sounds mean, finally after all this time someone with a 228 cam posted a vid thanks alot...
Old 09-16-2006, 10:39 AM
Rothman's Avatar
I know what you mean. I think I found one vid of a 228r before and I wasn't even positive it was one. Mine sounds a little lopy right now because it's not tuned, but it's also on a 110Lsa which Im sure is helping it lope a lil bit.
Old 09-16-2006, 01:08 PM
Rothman's Avatar
Wow it ran great today! untill the ****** passenger spring on my pro 5.0 went out and I jammed the car into secong doin 90. Now it's screwed. Thinking just bent rods but we'll see.
Old 09-16-2006, 03:13 PM
Charlie@LsXperts's Avatar
im runnin a 228r too....... ill post a vid soon through one chamber flows
Old 09-16-2006, 04:01 PM
That's what she said...
TheBlurLS1's Avatar
If you had hardened pushrods, you might have bent some valves.
Those missed shifts suck, been there done that. And don't blame it on the shifter........
Old 09-16-2006, 05:28 PM
Rothman's Avatar
Yeah I know a lot of it was driver error but, the springs on the 5.0 need changed. It's no longer self centering. It's more like first second centering.
Old 09-17-2006, 08:11 AM
Phil'sC5vette's Avatar
mine was installed about 2 months ago. check out my video link in the sig
