Running Newer Crank Reluctor Ring in Older Motor?
Old 09-16-2006, 08:46 PM
Ferocity02's Avatar
Default Running Newer Crank Reluctor Ring in Older Motor?
Despite what many will say, not all LS1 and LS6 engines got the same reluctor rings. The part number for the 24X LS reluctor ring from GM is 12559353, however, this ring is NOT what is on my stock 99 LS1 crankshaft. The teeth on my 99 reluctor ring are much closer together, there is no gap between the teeth on the two wheels. Also, the two wheels are much closer together than on the new reluctor rings. The old and the new rings may have the same teeth orientation, but they are visually different. I'm talking about 24X rings here, not 58X.
Now, does this difference affect the timing? Will the old crank position sensor react well to the new reluctor ring? I'm thinking of putting my stock reluctor wheel onto my Eagle crank. I'm taking the crank back to the shop because the reluctor wheel was not put on in the correct orientation, causing my car to run extremely poorly on only four cylinders.
Old 09-17-2006, 12:58 AM
Ferocity02's Avatar
Anyone?
Old 09-17-2006, 01:53 PM
Ferocity02's Avatar
Hello?
Old 09-17-2006, 02:10 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Well you need a same count reluctor wheel to run with your current pcm and crank sensor.
Old 03-23-2010, 09:03 AM
bww3588's Avatar
they are the same count, just different styles i guess you would say...
Old 03-23-2010, 12:27 PM
Ferocity02's Avatar
Way to chime in 4 years later
The newer style reluctor wheel worked fine, but does not work installed backwards (thanks "professional" engine shop)
Old 03-23-2010, 12:41 PM
bww3588's Avatar
sometimes bringing up dead threads is the way to get answers. and i got the one i wanted. i just hope having a 98 PCM doesnt change anything...
Quick Reply: Running Newer Crank Reluctor Ring in Older Motor?
