Best/Easiest way to remove oil pan?
Hello, well i have to remove my oil pan here and am curious the best way to do it. I have a 99 Trans Am, 4l60-e trans. Can someone give me some good steps as to what all i need to do from start to finish to get this sucker off and back on the easiest way? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
or would it be easiest to leave pan on and drill and tap it while installed? What do you guys think? Pan needs to be drilled and tapped, best way?
__________________
You have 1,940 and forgot about the search button? Wow!!
Why does it need to be tapped? Unless your 100% sure you will keep 100% shavings outta the pan, I would take it off.
ok thanks, i thought search has been broken for like a month now?!?! Anyway, yea i think i want to take pan off. i've heard i'll have to list my motor up just a tad to slip the pan out.... anything else? K-member way easier? Thanks!
__________________
Bump....
__________________
help please?
__________________
doesnt anyone have some tips on easiest way to remove pan?
__________________
When I removed the oil pan on the wifes car to replace the rod bolts I dropped the K-member a little bit. I didn't completely drop it though. But it was a bit of a pain to get the motor mounts lined back up again, then again that could have just been me though.
All in all though, another vote for dropping the K-member.
thanks, any others?
__________________
back up for some help
__________________
11Second Club
Sorry for the psuedo-off-topic question, but I've always heard people refer to dropping the K-member. The few times I've looked at it, it appears that the entire front suspension has to come off to get the K-member off. Is this not the case?
so dropping K-member is the easiest way then? Anyone beg to differ? If so, i will go that route!
__________________
