lifters tick after cam install,, Why?
I got the cam installed tonight and when I started it the lifters were ticking. I had it running for about a min or so and that was it. Is this normal to do this for a little while? Like I said it hasn't ran for more that a couple min.
Originally Posted by DaddySS
How was the oil pressure? What did you set preload at?
Originally Posted by vettenuts
If they bottom the valve would be held open. Not enough preload will tick, sewing machine noise is more from fast ramp rates. Noises are hard to describe without hearing, but a "tick" may indicate not enough preload, did you measure it?
