Changed the oil and found something werid.
I am in the process of getting my car ready for storage, so I changed the oil today. When I got the plug out I noticed some sludge on the end of the plug. I wiped it off and it is a dark silver in color. What could it be? Oil pressure is good 40 psi at idle when warm. Car has 70 K miles on it. I hope something is not starting to fail inside somewhere.
Now that I think about it, When I first bought the car 2 years ago; I changed the oil. When I pulled the plug out and found some grey sludge on it at 40K Miles. I have since changed over to synethic, and was pondering if It was cleaning the motor out; since dino oil was used since it was new. I dont know hoping for the best I guess. I will have to get an oil analysis, when I bring the car back out this spring.
Originally Posted by GuitsBoy
if its just a tiny bit, nothing to worry about. Ive had a little bit of silver stuck to the magnet every oil change since the car was new.
Originally Posted by DaddySS
That's pretty much the case. The bearing material isn't ferrous metal and so doesn't stick to a magnet. The cylinder sleeves, cam and lifters, timing chain and gears, oil pump, crankshaft journals etc. are all areas of potential friction and to have a little bit of metal "powder" on the drain plug is not unusual. An oil analysis from time is a good thing but if you have good pressure and don't hear any unusual noises you're probably just fine.
Thats good to hear
