trex with what heads?
tsp prc stg 1 ls6 heads with comp valve job. youre going want heads with stock sized valves so you dont have to flycut, and they are a good deal. i believe about $1200 with the comp valve job.
what kind of heads from etp.
ls1, ls6, or 5.3 heads and what stage.
i don't dd the car but i don't take it to the track that much either may 2 or 3 times a year
thanks
thanks
Our CNC ported 243 castings we have on special for $995.00 assembled will work well also. They have the oem 2.00"/1.55" oem valves, our 5 angle valve job, hand blended, our Patriot Gold Dual springs, ti retainers, etc. These heads are an excellent value and will perform well for you.
LS1Tech Premium Sponsor
Thanks for all the kind words on our PRC heads guys! We've worked really hard perfecting the ports with extensive dyno & flow testing!
If you get some extra time just look in the dyno section. I think you'll find the horsepower results you're looking for!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
