help picking heads and how much advance
well after months of reading about cams
i decided im going with
227/231 lsk lobes on a 110 +1,2,3 depending on the heads
the killer thing is im shifting it at 6500 with a 6600 rev limiter.
that cam sould have the most power for the shift point im using.
im shifting at 6500 because of the 98's rod bolts, and oiling system in the block, and due to 95,000 mi.
i was thinking about tsp 5.3 stage 2.5 heads. i read that the smaller heads would be better but i have no idea.
so how much advance should i have ground in and what heads optimize that cam and my 6500 shift points
