What should I do?
Old 12-06-2006, 10:26 AM
JD_Z28's Avatar
Default What should I do?
Recently I broke two valve springs. I noticed on one of them when I pulled the valve cover off I only found some of the broken spring, where would the rest of it go? What should I do before install the new heads I bought. what should I do?
Old 12-06-2006, 11:34 AM
Z28LS1camaroguy's Avatar
prolly in the block somewhere, check the oil in the oil pan for metal shards, could be more internal damage.
Old 12-06-2006, 11:55 AM
JD_Z28's Avatar
What would be the best way to search the block.
Old 12-06-2006, 12:41 PM
first look in the oil pan, just unbolt the oil pan bolt let the oil drain out and then see if there are any metal shards on the bolt since it is magnetic.
Old 12-06-2006, 12:51 PM
GuitsBoy's Avatar
yeah, they probably went into the oil pan. The pickup has a screen to keep the chunks from getting sucked back up.
JD_Z28's Avatar
Thanks i'll do that when I get home.
