Preliminary Warhawk ETP Canted Valve Results
Old 12-07-2006, 10:40 AM
Collections Hold
Cary@Perf-Induction's Avatar
Default Preliminary Warhawk ETP Canted Valve Results
We made our first couple pulls last night on our Warhawk based development engine.
We warmed it up and broke it in last night. We had a chance to make a few sweeps, the highest being 7500 RPM. we still have 2000 rpm to go. It is a 4 inch stroke with a 4.180 bore. With a custom ETP manifold and 2 Fast throttle bodies on top. Timing was at 25 degrees and AF ratio was still on the rich side, about 12.3-12.5 We will continue to make more pulls after the PRI Show next week where we will have the engine on display. Fuel was C-14 VP.
5000 505
5500 612
6000 700
6500 770
7000 831
7500 860
8000 TBD
8500 TBD
9000 TBD
9500 TBD
Old 12-07-2006, 10:43 AM
stevewix's Avatar
my monster cam 15:1 555 motor liked 13.7-13.9:1 afr, sounds crazy but i think the cylinder scavenging causes faulty o2 sensor readings. just some food for thought. congrats on your numbers!
Old 12-07-2006, 10:54 AM
gun5l1ng3r's Avatar
9500RPM!!!!!
How is that acheived?
What is the valvetrain and is the oiling system dry sump?
Is this just a regualr warhawk block with your heads on top?
Old 12-07-2006, 11:01 AM
Collections Hold
Default .....
5 stage dry sump
regular warhawk block with some machining mods
fast electronics
cam lift is over 1.00 lift
Old 12-07-2006, 11:37 AM
97BlackLT1TA's Avatar
holy ****
Old 12-07-2006, 11:49 AM
PowerShift408's Avatar
That is a lot of lift
Old 12-07-2006, 12:29 PM
SSZ
SSZ's Avatar
That thing is already making steam. Holy cow.
Old 12-07-2006, 01:16 PM
xfactor_pitbulls's Avatar
Wow, thats a whole new animal. Care to share the valve springs and rockers?
Old 12-07-2006, 02:18 PM
Tenured Member
Outlaw Motorsports's Avatar
good power
Old 12-07-2006, 02:35 PM
Tom@SpeedInc's Avatar
Do you have a pic? What size of throttle bodies?
Old 12-07-2006, 02:48 PM
The know it all's know it all
Sean Collins's Avatar
Rock on Guys Rock On.
5000 505
5500 612
6000 700
6500 770
7000 831
7500 860
8000 TBD
8500 TBD
9000 TBD
9500 TBD
Old 12-07-2006, 06:08 PM
383ss's Avatar
holy crap!
let see some pics of this thing! really want to see this intake!
is the the max bore you can go with these safely NA?
Old 12-07-2006, 06:10 PM
BlackHawk T/A's Avatar
Judging by the diminishing gains (if you plot those numbers on a curve) I don't think you will make power all the way to 9500rpm, even if you can spin it that high. You can always go prove me wrong though
You're crazy enough to try it though
Old 12-07-2006, 06:45 PM
matt346ls1's Avatar
Why did you stop at 7500?
Old 12-07-2006, 07:10 PM
I did some reverse math on this monster.
5000 rpm 530 lb ft
6000 rpm 612 lb ft
7500 rpm 602 lb ft
8500 rpm 540ish if the slope continues.
Motor could be peaked out but could be tunning etc. still one bad bitch at 860 hp.depend on how fast the TQ curve drops after 6000rpm could make alot more power. I don't think its finished yet however.
Old 12-07-2006, 09:40 PM
GrimReaper's Avatar
I would love to see what the lobes look like on that Beast!
Old 12-07-2006, 09:43 PM
landstuhltaylor's Avatar
mother of god
Old 12-07-2006, 10:54 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That thing's crazy! What type of SCR does that thing have? Have any pictures of the intake manifold, sounds interesting?
Old 12-08-2006, 03:38 AM
mr2guru's Avatar
Damn does that cam have offset lobes or something.....
Old 12-08-2006, 07:23 AM
allngn_c5's Avatar
Way beyond me, I have no idea what to say, but HOLY $hit. Lots of RPMS, HP, AND TQ.
Quick Reply: Preliminary Warhawk ETP Canted Valve Results
