Cam swap Advice!!
Cam swap Advice!!
Hey guys!!
Ive finally grown enough ***** to try the camswap my self..
Ive read over the ls1howto.com article MANY times and think Im ready..
I have all the tools....
Is there anything I should really be on the lookout for...
Thanks in advance!
Thanks in advance!
Just take your time and double check everything you do, and you should be fine. And like they said watch out for the spikes under the cowl they hurt!! Oh and make sure you have good valvespring tool I used the crane one and it was a life saver.
Dan
Dan
Originally Posted by PREDATOR-Z
Watch out for the plastic spikes under the cowl
yeah...take a knife and cut em off before u start. among many other things that will harm you.
i swear why didnt they just go ahead and fill the fbody engine compartment with thorns, snakes, and boiling pits of lava.
it might be the engine built by God, but the devil musta designed the rest of the car.
you dont have to cut off the plastic spikes. Just push up on them from the bottom and they will push out of the cowl. Then you can re use them when you're done.
Gotcha... It seems that those little spikes seem to be bastards!!!
Im doing a Head swap too... So I wont have to fool with putting VS on the heads!! Im sure I would mess that up BAD!! Ha
Thanks guys!
Thanks guys!
Originally Posted by ArrestMeRed99Z28
+1 on watching out for those spikes, actually, just cut them off. I have scars on my arm from those little ******* digging into my arm while i tried to fix my MAP sensor, last MAY!
Be very careful with the oil pupm bolt holding the pick up tube on. Use a ratchet wrench. it helps.
And most importantly take your time. Think everything through.
Like I did'nt know you had to shim springs to a certain hight. I just slapped'm on there and luckily they were crane duals. And there was no problem. I would rev thet thing to the moon!
You need a 24mm 6 point deep socket for the crank bolt, I'd recommend getting an impact socket instead of a regular one. You really have to crank on that thing to get the pulley seated. Also, a 10mm gear wrench w/ a flexible head can be a big help, but not needed. Good luck.
Do not do as advised on the install of the dampner! I followed the instructions used a longer bolt and the stock one broke on removal. Either buy a dampner install tool or heat it up.
