Which rockers
Which rockers
Im currently using 1.7 YT's, which some people seem to think arent too hot. Generally I only rev to about 6500rpm, although have taken it to 7000rpm with no apparent problems. It seems to peak around 6300rpm
Cam is 224/230 on 115, 0.581"/0.591", but I wouldnt have any concerns about upping that to 0.610 or so via 1.75 rockers.
CNC'd Edelbrock 215cc heads as supplied by WestCoast Racing heads. My pistons have cutouts in them.
I cannot lift the valve covers, as my coils will foul my brake booster, so basically stock covers must be retained.
I'd also prefer non-adjustable for ease of fitment.
The Jesel SS series look nice, but I think they require substantial clearance mods ?
Could I find a 1.75 ratio rocker that will fit ? Or should I stick with 1.7...
Crane ? Comp camps ? Harland Sharp ??
Im already using Trickflow pushrods.
Any advice is appreciated.
CRANE CAMS #144750A-16 gets my vote. there lightweight alum. body rocker with there quick lift geometery is an awsome feature. they are a variable ratio rocker, it will make the cam act bigger than it really is advertised. They are pricey, but diffently a killer rocker arm, besides going to there shaft set up. on average they make atleast 17rwhp, and 15rwtq. i srongly recommend double springs with these rockers though. have used them on three 4 different peoples engines and are very pleased with results. as far as what ratio to go with? the 1.7's would be great, but if you want to do the 1.8's your lift would be in the .613/.624 range.
0.624 sounds like a lot....Im currently on stock lifters. Springs are duals....no idea what brand. I believe they are good for 0.650", although I dont feel the need to go that aggressive.
I'd just like that extra bit of lift to take me over 600
I see Crane offer this in kit form, or as a set of 16 rockers/studs etc
Can I just buy the latter ?? At least, I dont need pushrods ?? ( Im on 7.4" )
your pushrods won't work, they are to long. the crane kit has been designed to be used with a certain length pushrod. it is much shorter than stock. you can buy everything seperately, but it's just easier to get the kit, and sell your stuff off used.
Originally Posted by 99blancoSS
Why not just save money and go with the Harland Sharp rebuild on the stock rockers?
Any comments on the Comp Cams pro-magnum 1.75 rockers, compared to the Crane 1.7 Gold. obviously the Comp Cams are a lot cheaper. ALso not sure how the cranes quick lift will affect overlap.... It might introduce a lot more than conventional rockers, which may be a bad thing, or may not.
Or is the 0.624" lift I'd hit with regular 1.8's nothing to be concerned about ?
Do 1.8's have valve more valve cover clearance issues ?
I'm not sure, but when I looked into the Jesels before I bought the Cranes I found that the pushrod holes needed to be elongated and there were a couple of other things too. Guess all I am saying is do some research on them before you pull the trigger. They are good rockers though.
Also, I think the Crane's are 1.72 fully open.
The trigger is itchin !!!!!
I do want to be sure what I buy is right for me.
I wonder which would actually offer more useable lift....regular 1.75's or the crane 1.7's
By that I mean, which would hold the valve open more, for the longest time for more air to actually enter the cylinder to make best use of the heads airflow ?
The cranes are starting to get tempting...
i would agree with doing the cranes, have used them on several different motors, and a by far the best rockers out there right now. they are pricey, but you are getting what you are paying for. i don't know of any other rockers who can deliver 20rwhp.
I can do a cam swap in situ...I just dont want to. Its a PITA
Rockers are easy, and as a few guys seem to think the YT's ( including W2W, so I take it they know ) arent that good....I want to change them anyway.
Originally Posted by bigdsz
I just had My OEM rockers with 80,000 miles rebuilt by Harland Sharpe for $250 for a 408 in the works. Lifetime warranty. All the aftermarket rockers IMO is a bunch of hype.
The added spring pressure and poor wipe pattern can lead to excess wear on the valve guides. Don't get me wrong, the stock rockers are excellent for a factory rocker, but at the same time GM set them up based on tolerance stack-ups so they could be bolted in place and have acceptable guide wear over the life of the motor with the low spring loads they were using. Then we come along, put in honking valve springs and fast ramp cams and all bets are off. I found with the Cranes, due to the adjustability, I could tighten up the wipe pattern to right where it should be and it was consistent between each valve. In my opinion, this is one area a lot of guys overlook when building their motors.
