Iron vs aluminum block: Lifting heads
How much better are the iron blocks holding down heads with some boost? I've talked to a couple people and they say the oversized head studs are a good idea for the aluminum blocks. What would be best things to do to an aluminum block and an iron block for 20-25 pounds of boost?
eirk@hkracingengines.com is building a 408 for me and he says guys comb the junk yards for the old blocks, presumably for the long bolts.
Its not only the heads lifting you have to worry about with alum but the block distorting as well. You'll require seasonal or every other season rebuilds (hone/rings) with the alum from block distortion and ring/cylinder wear.
Iron wont have the same problem in this respect. As for the heads look at a thicker deck design like AFR, DART, ETP etc.
Why do you like the long vs short head studs?
The older stuff was different lenghts and had deeper bolt holes.
As Chrispy said, the heads are a problem on either iron or aluminum blocks. The aftermarket thick deck heads are the way to go vs. factory heads.
We have aluminum blocks handleing that much boost after modifications just as well as the iron blocks.
Timing will have a greater affect on peak cylinder pressure than the boost in #'s.
