anyone have problems with ls6 oil pump?
Old 12-30-2006, 01:11 PM
00slowredz's Avatar
Default anyone have problems with ls6 oil pump?
i've heard mostly good things about the ported ls6 oil pump when you do a cam swap. after i bought the damn thing, i had at least 2 people tell me horror stories about them....anyone else? please explain
00slowredz's Avatar
if it helps, i bought the ported/shimmed one from sdpc
Old 12-30-2006, 01:28 PM
1sick'98WS6's Avatar
huh? if you think 70+ psi at wot is a bad thing, then no, no horror stories here. Mine has been great
Old 12-30-2006, 01:32 PM
Phantompooper's Avatar
Mine too, after I got the O-ring in there.....the second time......
Old 12-30-2006, 07:07 PM
Fratsit's Avatar
No problems at all with mine. I have the ported version from Texas Speed.
SDPC wont steer you wrong. You will be fine. Just make sure you dont cinch the oring. I took mine apart and put the body on, centered it, then installed the gears and cover.
R/
Frat
Old 12-30-2006, 07:13 PM
JRracing's Avatar
I've had no problems and its has 15K miles. 60+ lbs at cruising speed.
Old 12-30-2006, 07:15 PM
bfhawki's Avatar
I got mine from TSP when I did my head/cam swap. No problems so far.
CAM FOR SALE: Comp Cam 228/232 .588/.595 111+1
Old 12-30-2006, 07:17 PM
Phil'sC5vette's Avatar
[QUOTE=bfhawki]I got mine from TSP when I did my head/cam swap. No problems so far.
Me to. It's been two years and not problems. Lots of PSI
Old 12-30-2006, 11:05 PM
Blk97WS6's Avatar
+1 for no problems. plenty of PSI under normal driving and hard acceleration. i bought a ported one from Thunder racing.
Old 12-31-2006, 08:12 AM
LS1Tech Sponsor
Slowhawk's Avatar
We never had a problem with them.Of course we inhouse port them and set the pressure but never saw a problem before this.
