new timing chain for new cam is it nessesary?
depends on if you drive it daily and how many miles you have on it. i have the same cam you have and i reused my old chain, of course i only have 41k miles on my car and drive it less than 1500 miles a year. i think using the old chain will be fine, usually people change them out because youre allready there anyway so you might as well throw in a beefier chain.
I vote for a cahnge. When I did my swap the first time I had 6K on the car. The chain had noticeable slack in it. It was about a degree or two. When I did my second swap I threw on a double roller. But the LS2 chain will work perfectly. Its a small price to pay for such an important component.
is it OK to use it? depends, if you have anymore than like an eigth of an inch of play, i would say no go with an ls2 chain. slack is not your friend. Also, to save future trouble go with the ls2 chain.
thanks for the replies. looks like i will go with the old timing chain. the reason i'm going with the old timing chain because i tried to lower the oil pan (and i couldn't) to remove the oil pump to put the new timing chain in and i couldn't so i said to my self maybe it is OK to go with the old timing chain as some of you stated it is OK to go with the old one.
Dont go lazy on the timing chain. If you dont want to fork over the money for a double roller, at least go with the LS2 chain for 30 bucks. 30 bucks now, or a new engine when your slamming gears and the chain breaks? Your choice i guess
LS1Tech Sponsor
Closed ex-Sponsor Account
I've been to Kuwait twice, I remember traveling some of those highways, LS2 chain is looking good now
