high ratio rocker arm ??????
yes it is, it's usually better to get the desired lift from the cam rather than lifters, LS1 cams are spec'd out with 1.7 rocker if you go with a 1.8 you will have more lift and have to make sure your springs can handle it.
see i got the cam in my sig, and i didnt want go thru the whole process of doing the cam again till i get more money, i got a friend that will sell me his 1.8 rockers for $100, i was thinking about putting them on, you guys think ill see any gains or will i lose some driveablity,??
what if i just use em on the intake valves, so that ill get more air into the engine? just wondering if it will work, maybe im crazy for thinking this.
they're the SLP ones i beleive 1.8, my cam specs are 232/234 .595/.598 @112LSA
Originally Posted by JPH
.630/.631 will be your lift. i would rather see you with more lift on the intake side than the exhaust.
Problem is the XE-R ramps are too fast for 1.85 SLP rockers.
Originally Posted by PREDATOR-Z
Why? look at the original cam specs
It really depends on the rest of the VEs, you can't just say more intake lift is better in general. Also have to look at the use of the cam and its desired powerband.
so should i buy them from my friend and put them on only the intake side??
or should i save my money and buy another cam?
what do u guys think of PAT G's new torq grind? LSK lobes i believe?
thanx for the replys guys!!
https://ls1tech.com/forums/generation-iii-internal-engine/481382-torque-coming-out-my-ears-cam-change.html
https://ls1tech.com/forums/showthread.php?t=481382
