TSP 5.3L Stage 2.5 heads results inside
Old 01-08-2007, 08:14 PM
blazeone's Avatar
Default TSP 5.3L Stage 2.5 heads results inside
My '02 vette LS1 MN6 with Kooks LT's, hi-flow cats, Corsa cat back, Halltech stinger intake and MTI X1 cam made 384rwhp.
Added TSP heads, .040 cometic gaskets for 11.18:1 SCR and 8.55:1 DCR. Also added Shanner ported TB and ASP UD pulley. Before and after results below.
Here is a video of the run. Right click & save to target
Old 01-08-2007, 08:22 PM
john563's Avatar
Wow!! 40 rwhp from budget heads thats great.What are the specs on that cam? I just dropped My car off today to have those same heads installed.Im an A4 though with a Tr224/112 cam,also I ordered a ported 90/90 fast from Ron at Vengeance
Old 01-08-2007, 08:25 PM
slow trap's Avatar
your numbers does seem alittle low but not severely low. the ported tb,ud pulley and .040 gaskets ware probably good for alittle over 15 rw in reality so the heads were good for 20-25.i would think you are around 10 hp shy of where you should be.remember the ls6 intake might be hurting you more than before.
Old 01-08-2007, 08:41 PM
blazeone's Avatar
Added a video of the run.
Old 01-08-2007, 08:44 PM
brad8266's Avatar
40 Hp is a great gain for the price of those heads, I wouldnt be dissapointed. Wait till you get a FAST 90 with a 90mm TB.
Old 01-08-2007, 08:45 PM
blazeone's Avatar
Cam specs = 230/591 227/571 112LSA.
Old 01-08-2007, 08:46 PM
brad8266's Avatar
Good numbers for that size cam especially
Old 01-08-2007, 08:53 PM
01formula6's Avatar
The numbers don't look bad, but I would have expected a little more especially since you also add the TB, pulley and thinner gaskets at the same time. I would think your combo would be good for another 10-15 hp.
Old 01-09-2007, 12:05 AM
PREDATOR-Z's Avatar
Don't be wrapped in peak numbers, look at your undercurve, 350trq @ 3500 rpm is sweet.
Old 01-09-2007, 01:00 AM
lastcall190's Avatar
Great undercurve numbers, as stated! I was interested in these heads as they seem like a GREAT deal and I'm not going with a big cam, but rather a nice complete package with a "small-ish" cam. Interested in seeing what a 90/90 would do for you
Old 01-09-2007, 06:48 AM
blazeone's Avatar
Thanks, after checking out some other X1 head combo results with more expensive heads it looks like I'm doing pretty good. Also, there is probably a some more in it as we only had time for a rough re-tune and two pulls.
Old 01-09-2007, 07:07 AM
bjamick's Avatar
ya i would have hoped to see like maybe 430-440hp from that setup. The cam is not a huge cam but still does have a nice duration with a small lift though. Have you already had the car tuned?
Old 01-09-2007, 07:30 AM
john563's Avatar
Mine are going in right now and I have a small cam(TR224/112),and I ordered a poretd 90/90set up from Ron at Vengeance.Im an A4 and with the Tr224/112 I put down 348rwhp through a Ls6 intake.Ill let everyone know what the 5.3l heads and ported fast do with a small cam,and yes I was gonna add a bigger cam233/239,but did not get my Pm returned,but we'll see waht it puts down next wk
