Boring an LS1 Block to clean up cylinder walls.... How much is too much?
Had some divits where bad piston rings wore at the top of the cylinder where the piston ring ends so I need to bore it over.
Some people have said that boring it anymore than 10 over is too much. Some say it's not....
For the guru's: What's the most you would want to bore a stock block over without putting in sleeves? All I need it 20 over to clear the divits and go with some forged pistons/rods.
Will that make the cylinder walls too thin??
Someone please explain why or why not. Thanks guys!!
3.910 is the max for the 2000 up blocks. Anymore and you are going beyond what is recomended although people have done it to success. Even so a .020 piston may be hard to find or impossible. If it is a 98 to mid 99ish block you can only bore to 3.908 I believe might be less than that never researched it since my block is 02.
Average bore safe use 97/98 and some 99 .007 hone
Some 99 + can go with .01 but still better leave some meat and go with .007
So in general for street better be safe and not go beyond 3.905 bore
I was talking to somoene recently who bored theirs to .030 over and was pushing out 700hp with no problems in their track only car. So, it can be done and it has been done. As for safety and reliability, that's up to you decide. The less you hone/bore, the safer (obviously). You just have to find your comfort zone in the balance.
How many people think that it would be okay to go .020 over??? Like I've said before, I've been told that anything more than .010 over is asking for trouble b/c of thinning the cylinder walls.
Also, someone else told me that the cylinder walls in an LS1 block were sleeved in, not cast in? You can't cast cylinder walls in an aluminum block, can you??
7 Second Club
Originally Posted by pist0lpete
Another thing to consider is if you decided to risk it and go 20 over where in the world are you gonna find 20 over pistons and a set of rings?
