just got my new cam and lifters in, will it tick like hell?
What should i expect? Since i have new lifters is it going to tick real bad when i first start it? Should I crank the engine over without the coils hooked up to get oil pressure to the lifters before i start it?
formerly silverbrick (changed 02/17/2013)
just start it up and pay good attention to oil pressure. if it doesnt go up after the first 5 seconds or so, turn it off and say 'WTF'. It will tick but it'll be fine. Turn the key.
I didn't soak them because Vettenuts told me not to. He said if they are soaked then it could hold the valve open and then it may come in contact with the piston. I did dip them in oil before i put them in. Oh, and i didn't change the oil pump so I'm sure it will have oil pressure.
Before you button the covers on, pour some oil on lifters, rockers, p-rods to help with start up. Of course dont forget to change your oil before that and leave a bit out (the amount you pour from top).
I would crank it over w/ coils not connected till it builds up oil pressure. also did you crank the motor by hand several times to make sure it will turn over when u use the key. once both are done you will have that piece of mind and it will crank right up. ticking yes till lifters get oil in them. on first fire up do not give it some throttle, maybe to keep it idleing till it can on it's own. just some suggestions here. this is how I approached mine. good luck.
fuerzaws6
fuerzaws6
I am assume you cleaned the lifters in a solvent (mineral spirits), cleaned them off, then put them in oil for about an hour or less, just to get the air bubbles out and make sure the oil gets to the rollers.
Just pull the PCM/IGN fuse and crank it over to build pressure. Run the starter for 3 seconds at a time, and on the third spin you should see the oil pressure come up.
I would pull the fuse on the fuel pump and unclip the coils leaving out the plugs. If you spin it a few times the oil pressure will come up. Mine came up to about 30 psi. Did you use any assembly lube?
They will be noisy for several minutes. When I put in the Morels, Rick Morel told me they might clack for as long as 20 minutes depending on temp and how long it took for the grease to wash out.
Originally Posted by vettenuts
While some of the aftermarket manufacturers recommend this, the service manual doesn't for stock lifters. Morel warns against doing this as their lifters have a special grease inside and washing it out is bad for the lifter. Since he installed stock lifters, he followed the service manual.
You're right - I see no reference to cleaning stock lifters but I can't imagine they are not coated with anticorrosion compounds. I usually recommend following the maufacturers directions but I would be tempted to clean and lube the stock lifters.
I just started my car for the first time since install today, cranked it over with coil packs unplugged..took about 10 seconds to build 40psi. Then started it up, and watched the guage to make sure it maintained pres. No probs doing it this way, all went well.
I like to dip my lifter in oil before installing, but I too wouldnt soak them for the same reason stated above. Granted the spring pressure should bleed the lifter down pretty quickly, but I just dont like the idea. Like predator-z said, coat everything with oil just before putting the valve covers on.
It usually takes about 5 seconds or so before oil pressure shows up, but you may hear some hellacious clatter for up to half a minute before the lifters are fully pumped up.
Actually, what Marc did was soak the lower end of the lifter and work the oil into the roller then dip/coat them and the lifter bore thoroughly before installation. I have read a couple of instances with a cam where the lifters were soaked and basically hard (solid) such that they actually over opened the valve and contacted the piston.
Lifters (Comp or stock) should be cleaned outside with mineral spirit to remove coating and then dipped in light oil 1hr or so before install.
That is impossible because upon install they will bleed. Only way this happens is if the p-rods are too tall to begin with and are trying to colapse the lifter before they bleed.
