Z06 oil pressure
Z06 oil pressure
I have a 2001 Z06 and my oil pressure is showing 130 psi on the info cluster. I would assume that this is not normal. What would be a normal reading and any thoughts as to the problem?
Thanks
Thanks
Originally Posted by ABrianBaker
I have a 2001 Z06 and my oil pressure is showing 130 psi on the info cluster. I would assume that this is not normal. What would not be a normal reading and any thoughts as to the problem?
Thanks
Thanks
Hammer
There is a great post over on the Corvette forum regarding relocating the pressure sensor over to the side of the block for easier access.
It is not uncommon to hear of these sensors lasting a few weeks or less.
Relocation would eliminate the need to remove the intake every time it craps out.
sender relocate
sender relocate
