the most power on 93 octane?
I tried a search & got nothing.
In a turbo set up, What engine/turbo combo would make big numbers on 93 octane? I see most turbo cars make + or - 650rwhp on pump gas.
Ive seen a vid of a turbo viper make about 1K rwhp on 93 (488cid) I cant find the vid right now. Ive seen a chevelle 347 TT make 750rwhp.
A big motor with a big turbo will make the most on pump gas right?
Why do some set ups make more than others even though there almost the same?
Originally Posted by SVTlightning87
is it true you dont go as far on a tank of E85 then 93? in theory would E85 fuel keep a stock short block alive longer due to less detonation?
You are correct, if use use E85 you do consume more than standard gas. You do have to change your fuel system over to accept alcohol.
Well, This is what im talking about. The T/A in this vid made 884 rwhp on 91 octane @ 15 psi.
http://videos.streetfire.net/search/...bf000d373d.htm
If you go on speed inc's site & look at the single turbo kit it says "We made 675hp on 93 octane" So why did this T/A make more power? What & where are the limits?
