Ok I am confused 918 springs or 921 springs
Old 01-26-2007, 06:26 PM
marcdez's Avatar
Default Ok I am confused 918 springs or 921 springs
Ok I am confused 918 springs or 921 springs for a TSP 231/237 cam on a 112 lsa. Also I wanted to know if this will work with the stock gear or if I am going to need the 410 gear if so is there is another cam with good mid range and top end HP and Torque that will work with the 918 springs and that I will not need to get a 410 gear for. Also those springs are expensive the 921s are like 599 thats more than the cam costs. Just dont want to f@ck this up and get the wrong stuff for my set up. My set up is in the signature. I might just get some heads to go with my existing cam I am getting confused?????
Old 01-26-2007, 06:44 PM
thehammer69's Avatar
I don't know what the lift specs are on that cam since you didn't post them...what i do know is that I know some tuners don't like to run 918's above .580 even though they are rated to someting like .600-.610. So i would guesstimate that 921's would be the better choice.
Hammer
Old 01-26-2007, 06:46 PM
marcdez's Avatar
Ok good input anyone else?
Old 01-26-2007, 06:53 PM
david vericker's Avatar
The 918 springs are good up to 600 lift. If you plan on going bigger than 600 lift its adviseable to go with a dule spring setup. Is this an A4 or M6 CAR? Theres a big differance in the stock gear. M6 car - 373 or 390 gear would due the trick, but then again the 411 gear wouldn't hurt. A4 car - buy a stall converter too.
Old 01-26-2007, 07:02 PM
marcdez's Avatar
The cam is 231/237.598/.595 and the car is a 6 speed. Ok I am starting to get the picture. So if I dont want to get a gear maybe I should get a cheatr cam that way I wont have to get the gear to get to the HP and it is still a little bigger than my lingenfelter GT2-3 cam that I have installed now.
Old 01-26-2007, 07:12 PM
Jasonscott's Avatar
I just bought the cam that you are talking about, the 231/237 and I think the lift is .595/.598. Im going to use the 918's with mine. From what I understand this cam has fairly mild ramp rates and should work just fine with those springs. The springs are actually capable of more than there advertised lift maximum. I think there good for .605-.610. As far as gears go, I think Im going to go with 4.10's, but Im gonna wait till the cam's in and see how it drives.
Old 01-26-2007, 07:14 PM
JPH
JPH's Avatar
918 springs wotk fine. a4 or m6 car?
Old 01-26-2007, 07:16 PM
I blewup my 390 gear just before DW 06. Theres a 342 gear in my car right now and it works just fine,however,I do have a Tremec close ratio 6 speed which does compensate somewhat for the lack of gear.
Old 01-26-2007, 07:37 PM
marcdez's Avatar
Let me know how that goes if you can I would appreciate it.
Old 01-27-2007, 12:17 AM
PREDATOR-Z's Avatar
That cam is a dawg without proper supporting mods.
Go with a TR230/224 111lsa, much better suited for the task and you can run 918's with that one all day..
Old 01-27-2007, 01:11 AM
Chicago Crew UnderBoss's Avatar
If you go with that 231/237 TSP cam you would be a FOOL in my opinion to run 918s and you CERTAINLY would want to run an excellent battle tested dual spring such as the PRC Golds, Patriot Golds, COmp 921s. 918s are great for less agressive cam but that cam has a fairly agressive street cam and you NEED DUAL SPRINGS for protection against having a second spring hold up the valve if a spring breaks. Good cheap insurance and the PRCs Gold and Patriots are very reasonably priced!!
Old 01-27-2007, 03:22 AM
PREDATOR-Z's Avatar
Do you speak from experience or net phobia.
First of all the 231/237 is a LUNATI grind with less agressive ramps than XE-R
918's can handle much more than that (I've ran a .612 lift XE-R for 17K miles on these) and pulls till 6800rpm.
So please stop this nonsense
Old 01-27-2007, 08:25 AM
NoMoreFWD's Avatar
Even with the dual springs, if one breaks you are going to drop a valve.
Old 01-27-2007, 10:55 AM
I speak from experience only in the sense that I have broken dual valve springs before on a heads/cam C5 and the valve did not drop and I was in good shape after getting them replaced (and having that dual spring lessens the chance of a valve dropping as I am sure you would agree)?
You are right that 918s are excellent springs and are battle tested but I do know a couple of people who broke a 918 with a cam with less lift than the TSP one he references, and a valve dropped fragging his entire motor) and why not have the insurance and better piece of mind of an excellent battle tested very AFFORDABLE dual spring with a .600 lift cam for insurance and to minimize the chance of a valve dropping if you break a spring!!
As far as being the resident cam expert that I am not and that would BE YOU, and I say that will all sincerity as you have even helped me out quite a bit in specing out a nice blower cam about thist time last year and thank you for all your help with that
Old 01-27-2007, 11:01 AM
PREDATOR-Z's Avatar
I speak from experience only in the sense that I have broken dual valve springs before on a heads/cam C5 and the valve did not drop and I was in good shape after getting them replaced.
You are right that 918s are excellent springs and are battle tested but of course i know a couple of people personally who broke one with a cam with less lift than the TSP one he references, and why not have the insurance and better piece of mind of an excellent battle tested very AFFORDABLE dual spring with a .600 lift cam for insurance and to minimize the chance of a valve dropping if you break a spring!!
As far as being the resident cam expert that I am not and that would be you and I say that will all sincerity as you have even helped me out quite a bit in specing out a nice blower cam about thist time last year and thanks!
My apologies if I sounded harsh, but I wasn't.
It is just that Newbs take such comments seriously. 918's are darn good springs and IMO, unless you have too, those are the ones to run.
Glad to hear that your huffer is making serious power.
Old 01-27-2007, 11:14 AM
fastest94v6's Avatar
Z in the house!
Old 01-27-2007, 12:51 PM
No harm no foul, I and many other people just prefer the peace of mind and added insurance of a good double valve spring on a .600 lift LS series cam that is most likely to be seeing around 6800 rpm.
Old 01-27-2007, 01:41 PM
marcdez's Avatar
Ok this sounds great who makes this cam and is the torque and HP good on the mid range rpm to the high rpm.
Old 01-27-2007, 02:08 PM
NoMoreFWD's Avatar
It's so nice to see everyone getting along, so well. 427 I have seen stock vehicles saved by the inner spring before. I think a car with a bigger cam and high revs, might not fare so well if a spring breaks. I could be wrong.
Old 01-27-2007, 06:59 PM
marcdez's Avatar
Just wanted to say thanks for all the help I did some more reasearch and called and ordered this cam 99-TR230/224-111 Thunder Racing Custom "Reverse Split" Camshaft - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Automatic cars require computer tuning and it is recommend for optimum results on manual transmission cars
it is going to be about a monh or 2 until I install it I need to get a new clutch to but thats going to be another thread. After I get it installed and tuned I will post the numbers on this thread. Thaks again for all the help especially pedator-z
Quick Reply: Ok I am confused 918 springs or 921 springs
