Everything is hooked up, but no radio, and engine won't turn over. PLZ HELP!
Old 02-04-2007, 12:19 AM
JLSain's Avatar
Default Everything is hooked up, but no radio, and engine won't turn over. PLZ HELP!
Just put my engine back in, I have everything hooked up, but my radio does not work, and when I turn the key, the interior bell dings while I have the key turned. Any ideas on where to look?
Old 02-04-2007, 12:23 AM
Hawk108's Avatar
Check the battery connections?
Old 02-04-2007, 12:24 AM
JLSain's Avatar
Yes. They are good. ???? LOL. It's late and I've been working on this car ALL day lol....
Old 02-04-2007, 12:46 AM
connexion2005's Avatar
will the car even turn over at all?...check the starter connections and any electrical
Old 02-04-2007, 01:59 AM
nofearracing28's Avatar
sounds like somethin to do with the starter
Old 02-04-2007, 08:46 AM
CamminV6's Avatar
I was helping him last night, you think it could be the main ground that goes from the battery to the block?? The ground to the head is on and correct for sure, seems like maybe the main ground is not right???
Old 02-04-2007, 09:47 AM
99blancoSS's Avatar
Sounds like a possible ground issue. There is more than one ground off the engine harness. One on passenger side one on drivers side to frame rail.
Attached Thumbnails Everything is hooked up, but no radio, and engine won't turn over. PLZ HELP!-frame-ground.jpg
Old 02-04-2007, 11:08 AM
CamminV6's Avatar
we have that one and the one on the head connected, you have apicture of how the main engine ground should look??
Old 02-04-2007, 11:27 AM
JLSain's Avatar
I think I know what it is now....
I have the 10 gauge black cable bolted to the starter, not the block. That's gotta be it.
Old 02-04-2007, 11:28 AM
99blancoSS's Avatar
I'll check, battery is fully charge right? A weak battery will give you all kinds of issues.
99blancoSS's Avatar
Yes that sounds wrong, it goes to block
Old 02-04-2007, 11:35 AM
JLSain's Avatar
Where on the block does it bolt?
Old 02-04-2007, 11:38 AM
99blancoSS's Avatar
theres a couple holes next to each other near the motor mount I think, above it slightly forward or back. Cant remember exacty but you'll see it. My car isnt home right now, cant go look.
Old 02-04-2007, 11:42 AM
JLSain's Avatar
Which would explain why everything worked (radio, windows, etc) until I turned the key. This also explains why the alarm still works too.
Old 02-04-2007, 03:32 PM
JLSain's Avatar
She's running. Since I didn't have it grounded properly, it blew the 50A ignition maxi fuse. Thanks for the help guys! I have another small problem with it not wanting to let coolant into the engine. Air pocket maybe?
Old 02-04-2007, 03:45 PM
cav101's Avatar
are you adding coolant the correct way.......remember, reverse cooling....?
Old 02-04-2007, 03:51 PM
JLSain's Avatar
No I'm not. Please explain. Newbie here!
Old 02-04-2007, 05:07 PM
cav101's Avatar
from my experience (this is an ls1 in a 3rd gen), filling it like a gen1 sbc doesnt work. Fill the rad, then fill the motor, via hose connected to the water pump.
Old 02-04-2007, 05:44 PM
crainholio's Avatar
Someday, when you realize the LS1 doesn't use reverse flow cooling, you'll feel bad for having posted this...
Old 02-04-2007, 05:48 PM
cav101's Avatar
lol.....still learning myself.....tried filling mine the same way as a gen 1, and it wouldnt let me add more. tried it the other way, worked good.
