MTI cam on stock z28
Hey guys, Im getting a mti x1 cam 230, 227, 591, 571 112 lsa and comp 918 springs on a A4 2000 z28 with, my car is stock I just got loudmouth I exhaust and k&n filter, what else do I need? (pushrods,retainers), and what's the best I can get? I dont drive it too much, its not a daily driven car.
Im also installing pacesetter ypipe and headers, 3.90 motive gear, transgo and transcooler soon
Thanks
Thanks
Stall for sure, p-rods and spring locks, of course some gaskets, and LS6 oil pump + LS2 chain.
http://www.ls1howto.com explains a lot of the necessities
Thanks, which pushrods and spring locks would you recommend me? do you think an ls2 chain would do or should i better get a double chain? to make a double chain conversion, do I only need double cam and crank gears?
I would think the LS2 timing chain would be sufficient, that is what I plan on going with after alot of research. As said before I would look into getting a TC and have it stalled around 3200-3600, to get you into your powerband.
stock size pushrods would work, they are 7.4", go for some chromoly hardened pushrods. Titanium retainers seem to be common addition when doing cam install.
