Couple a questions about my AFR heads?
(1) What size brass plug fits into the water temp sender hole?
(2) I got a new set of GM head bolts but the AFR head instructions have a lot of instruction and recomend ARP head bolts (as well as washers) what do you all think?
TIA!
TIA!
TIA!
TIA!
2. ARP head studs are your best bet. You clean the bolt holes only once, install em and never have to buy new bolts or clean the holes out again.
Originally Posted by brad8266
1. I pretty sure its 1/8th
so for me it would cost about $140 shipped from say Thunder Racing? I already have a set of brand new GM bolts so is it worth it or not??
I just put my AFR heads on about an hour ago and I re used my ARP bolts. I did not buy studs as they cost a bit more. But if I had to buy them again, I would use studs. Studs have better clamping force than bolts.
Originally Posted by JRracing
Yes, it's worth it. They are 3 times stronger than stock bolts.
113-234-4110 ARP Hex Head Stud Kit; LS1 thru 2003 $236.99
113-234-4316 ARP 12 pt. Head Stud Kit, LS1 thru 2003 $258.99
So which one?
how any explanation would be great or install tips?
another plus about the arp head studs/bolts is you torque them to ftlbs instead of the degree method which sucks if the motor is in the car.but as said they are reuseable and are much stronger so it is a good investment.
so install them to what and how with an allen wrench
also 1/8 brass plug is all i need to order to plug the temp sender unit hole? no other measurements needed?
Thanks a bunch everyone this is what makes this site so great!!!!
bolts into bolt hole hand tight put gasket on then heads, then tighten studs with allen wrench fitting to 75 lbs, then put washer/nut on stud and tighten to what?
click this and go to page 40 http://www.arp-bolts.com/Catalog/Catalog.html
