TR "Old Man" or "Cheater" cam
If anyone has experience & Dyno results for these cams(on a stock rear end) please post.
I was choosing between these two for my DD. It wont see the track at ALL(maybe for one 1/4 run for time). I only want around 365-380hp max. Does anyone think one of these cams or any suggested cam that could get me in this hp range?
hay bro thru my experince i had tr224 and i gain 365 only long tube headers and pullys and ram air.tr224 was the best choise i had in thunder racing for dd cam its the best choise with little loby idle sheater is verey good cam too but u well loose alot of torque in low rpm but it well give u factory idle
but if u dont mind a little loby idle i preffer tsp 228r u well get like 370 to 380hp with good tuning
but tr224 its makin verey good power too its the best for dd i got 402hp with 205 dart heads with verey bad tuning .
good luck man
good luck man
You've got headers so the cheatR will be rougher on your valve train than you probably want on a DD. The old man is a little better but if you only want 360 to 385 I would look at TR220, comp 216 220, LS6 cam or something in that range.
OK I'll consider the TR220 & TR224 cam from Thunder(I thought it was too big for the hp range).
I did look at the LS6 cam, but couldn't find Dyno #s on it. Do I need longer push rods for the LS6 cam?
yep propably u well need with ls6 but u dont want to go for it man its not much of wow cam
and tr224 is not big cam at all its street cam 100% i install it without tuning for tow month before i dyno it and its was workin well put 345 hp no tuning .
go for it and u well not gonna be disapointed.
LS1 Tech Administrator
FYI, the Old Man Cam and the CheaTR use the same 215 .600" intake lobe. The CheaTR uses a larger 230 exhaust lobe and the OMC uses a smaller 222 low lift lobe. The OMC is better with headers, the CheaTR is better with manifolds.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Like a XE or XE-R lobe.
Random question to add into that.... Would either of those cams work on a stock PCM tune and not need a stall converter on an auto? I'm also looking into a cam sometime this summer.
Now I'm leaning more to the Old Man cam, but I will check on more of the TR224.
I'm stuck on TR cams cuz they're close to my house and they can do the swap for me. I guess no one on here had the OMC. I wanted to hear some SOTP comparisons.
Originally Posted by YankeeVert.
How come they didn't use a lobe with more lift?
IIRC, They weren't too concerned about maximizing the exhaust lobe. I'd like to see it with thier lobe from their 220/220 cam.
Originally Posted by 1989GTA
I don't know but .600" lift with 215 degrees of duration looks like a lot of lift to me.
my cam was designed very similar to the cheatr...its a custom grind but i couldnt be happier with it as a dd. there's power at every rpm
214/230
.601/.613
112 LSA
