best dd cam?
Old 02-20-2007, 09:48 PM
WsFirebird6's Avatar
Default best dd cam?
well i have a 98 ws6 but technically the car is my dads, he wants to keep it pretty much stock, but i want to go the way of a cam, what would help settle both our needs, i want power and he wants something that wont affect reliability or gas mileage much, any help? thx
Old 02-20-2007, 09:51 PM
Disturbed Bird's Avatar
TR224/224-114 or TR224/224-112
the 112 will be a little more choppy at idal
Old 02-20-2007, 10:16 PM
Phantompooper's Avatar
I was going to recommend my cam. It's a fairly low duration/higher-lift cam. 222/222 at a .566"/.566" with a 112 LSA. It's a Comp Cams Extreme custom grind. I used to daily drive the car and you can only really tell it's cammed when I open the cutout.
Old 02-20-2007, 10:24 PM
just dont go above a 224 or u u will notice a gas milage decrease or call thunderracing and talk to them they will be able to answer all ur questions they answered all of mine.
Old 02-20-2007, 10:30 PM
justin b's Avatar
if you want to keep mileage close and drive it a ton with no worries,i say gm hotcam,good power and easy on valvetrain ,and still gives it a lopey idle
Old 02-20-2007, 11:08 PM
Camaro Rick's Avatar
+2 on the nothing above 224.
I'd recommend my cam as well. Stock like street manners. Combine it with a set of 243's and you'll have an animal that drives like stock.
Old 02-20-2007, 11:38 PM
Cop Car's Avatar
G5x3 on 110. no joke.
Old 02-21-2007, 12:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Anything can be DD'ed with a tune for the street. Just shy of a solid roller in the 260+'s
Old 02-21-2007, 12:53 AM
bad95killer's Avatar
I'd say TR224/224 on 114LSA
peace
Old 02-21-2007, 01:11 AM
sidewayz28's Avatar
232/234 .595/.598 112 FOR THE MUDA PHUKIN WIN!!! if you can get it tuned, itll all be good my man
Old 02-21-2007, 02:21 AM
Cop Car's Avatar
yes, nobody belives me when i tell them my cammed car behaves the same as my friends car with a 4000 stall and bolt ons... just that my car pulls so much harder.
Old 02-21-2007, 12:10 PM
DanZ28's Avatar
peace
Ditto!
OR, the MTI stealth cam.
Dan
Old 02-21-2007, 01:29 PM
JPH
JPH's Avatar
220/224 .585/.585 114, great daily driver cam that makes excellent trq and hp. strong trq from 2500-5600, and peak hp at 6000. the rpm range of thse cam is 2200-6100.
Old 02-21-2007, 03:44 PM
SSwt00SS's Avatar
i have a Comp Cam 224: 224/224 .581/.581 @112lsa and its a great under the curve power cam (not a peak #/dyno queen cam). It's pretty much the same specs as the TR224. Go with a 224 and you will be pleased...
Old 02-21-2007, 04:43 PM
Ryan02SS's Avatar
Stick with a 224 grind of your choice. I prefer the 112LSA over a wider LSA. Bump the idle to 900-925rpms and it will purr with no driveability issues assuming a good tune is performed. My setup drives very much like stock but with alot more power. I DD the car alot during good weather.
Old 02-21-2007, 05:15 PM
gts500's Avatar
hmmm if its dads car thats mean u dont want to much of rough i dle and shaky start
i will recommend sheater cam in thunderracing its pretty good cam its well give u power all around the rpms like the 224 with slight decrease in low end torque but it has a stealth idle like factory. good luck
Old 02-21-2007, 07:14 PM
2 SSlow's Avatar
depends on your tolerance of a modded car...
I daily drive a TSP 233/239, its all in the tune though. It drives stockish once its warmed up lol. I went with a TR227 to start. It was an EXCELLENT daily driver cam...then i decided the driveability was TOO good. Went with the 233/239, and still wouldnt mind something a little bigger
Old 02-21-2007, 08:25 PM
xfactor_pitbulls's Avatar
LMAO, I love it when people say stuff like TRex, no problem. You can make them drive like stock if the tune is right. Funny thing is that I have never experienced that. I would say something in the 224/.580 114 range. Those other cams will change the driving manors from stock. Not saying you couldnt DD it, but there will be a substancial driving difference to those larger cams.
Old 02-21-2007, 08:31 PM
austin21's Avatar
g5x2 on a 112 +a good tune ...thats all you will need
