TREX lows #'s. Not Happy....
Old 02-23-2007, 12:17 PM
TheCarKid's Avatar
Unhappy TREX low #'s. Not Happy....
Check out my sig for all my mods to date. I've heard a ton of good things about the Trex cam and now I've got one and I can't seem to get the numbers that everyone else has. Cam only tune was 375rwhp and about 365rwtq. Cam and heads was 402rwhp and about 380rwtq. Short block has new bearings, balanced rotating assembly with diamond forged pistons and it's almost newly done(about 1,000 miles) so i don't think it can be anything crazy in the bottom end. I only have the LS1 intake right now but even then i should see much better numbers. I don't know what else to do.
Anyone got any ideas on what's going on? too conservative of a tune?
Old 02-23-2007, 12:19 PM
VinR1's Avatar
cam-only numbers arent too bad but are a bit low with the heads... what/whos dyno was this on? do you have a sheet you can post?
Old 02-23-2007, 12:21 PM
TheCarKid's Avatar
i don't have the sheet anymore i was cleaning the garage and tossed it i think. Car was dyno tuned by Speed Inc.
Old 02-23-2007, 12:31 PM
00BlueTA's Avatar
What cc heads did you buy and what size intake runner are they. If the intake runners are big or the comp ratio is too low you will produce low numbers.
Old 02-23-2007, 12:38 PM
TheCarKid's Avatar
TSP's CNC ported LS6 stg.1 heads. should be stock cc's. as far as runner size i'm not sure. they don't specify on the website. I know i'll lose a lil bit from the -2cc valve reliefs in the pistons but i'm not sure if that would explain my low numbers.
Old 02-23-2007, 12:50 PM
N4cer's Avatar
That shouldn't explain numbers that low.
Old 02-23-2007, 01:16 PM
TheCarKid's Avatar
As far as 1/4 mile times last run was 12.32 @ 116mph. Does that seem low too?
Old 02-23-2007, 01:22 PM
PunkNPonys's Avatar
The LS1 intake is costing you about 15-20rwhp so thats one problem. The car is probably starving for air.
LS1 Tech Administrator
Patrick G's Avatar
I tuned a cam-only LS1 with a T-Rex to 450 rwhp and 405 rwtq (of course, it had HVMC headers, FAST 90, and all the best bolt-ons). Cam-only, you should be higher than you are now. With ported heads, you should be even higher than that. Can you show us the graph? It would be interesting to see where you make peak power and torque and how your tq looks at 3000 rpm. Cam could be in at wrong centerline.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Bryan @ Speed Inc.'s Avatar
ls6 intake at the least.
FAST 90 would gain you around 30rwhp with that big of a cam + ported ls6 heads.
Old 02-23-2007, 01:23 PM
92SilverSHO's Avatar
the intake is EASILY costing you 20rwhp like was said. Put on a ported fast or if you don't have much cash, get an ls6 intake.
Old 02-23-2007, 01:27 PM
sick looking car man... got an F-quick or anything?
Old 02-23-2007, 06:43 PM
TheCarKid's Avatar
I'll see if I can find the dyno sheet. I cleaned out my garage over the winter but i might have it somewhere.
Old 02-23-2007, 06:52 PM
PunkNPonys's Avatar
Thanks man. F-quick?
Old 02-23-2007, 06:56 PM
CougarL92's Avatar
Trex is a great cam for Stock cubes
Old 02-23-2007, 07:04 PM
TheCarKid's Avatar
This was my latest dyno run.
2000 Trans Am M6
347-forged diamond pistons w/ -2cc valve reliefs
SLP Lid and smooth bellows
160* Thermostat
TSP Stg 1 LS6 CNC Ported heads
Trex Camshaft from Thunder Racing
LS1 Intake Manifold-stock injectors
Pacesetter LT's, ORY and SLP Loudmouth Catback
Stock 10 bolt w/ 4.10 gear
Old 02-23-2007, 07:07 PM
NoGamesLS1's Avatar
Hey your biggest problem is that fing ls1 intake. Swap it out for a ls6 intake. I bet you see over 30rwhp jump. That big cam likes to move air and the ls1 intake restricts it like CRAZY. Also whats your compression?
Old 02-23-2007, 07:14 PM
TheCarKid's Avatar
I'm gonna get a new intake in the near future. Compression ratio should be close to stock if not a lil lower with the -2cc valve reliefs. As far as actual cylinder compression i haven't checked it since before i put new pistons in it.
Old 02-23-2007, 07:17 PM
NoGamesLS1's Avatar
I take it the heads are not milled?
Old 02-23-2007, 07:19 PM
NoGamesLS1's Avatar
Also what is your head gasket thicknes?
Quick Reply: TREX lows #'s. Not Happy....
