Rockers Arms
Rockers Arms
So I pulled the drain plug last night and found all the needle bearings from my rocker arms. How many of you guys are running stock rockers on heads cam set ups? Im just trying to decide if I want to go aftermarket or not, and if so whats some reccomendations. I have a f13 and all the supporting mods in my valvetrain.
heard mostly from 99 prior year, harlan sharp will up grade trunion. thats supposed to prevent from bearing falling out. if you go after-market rockers I would look into HS or YT. .02
fuerzaws6
fuerzaws6
Just a FYI the HS rockers on my wife's car seem to cause a little float around 6600 RPM because of their weight. We are thinking of going back to the stockers with the HS trunion mod... *shrug*
my rockers are coming apart as well. GM knows it's a common issue since there is a Tech Bulletin for it. 02-06-01-029 applies to 1998-02 4.8, 5.3, 5.7 and 6.0. camaro, corvette, yukon, sierra, silverado, tahoe, suburban, hummer h2 and avalanche. replace with part# 10214664(X16) (16 rockers total). i will be doing mine soon.
12 Second Truck Club
what did they change about the rockers? i have a 04 tahoe and will be useing my rockers for my 383 build. are the newer one safer or should i still do the HS mod?
