ARP Head Stud will not come out?!?!?
Old 03-12-2007, 09:35 AM
SideStep's Avatar
Question ARP Head Stud will not come out?!?!?
I have one ARP Head Stud that will not come out... all the others come out by hand using an allen wrench.
Any ideas/suggestions?
Is the special tool made to remove head studs that have seized???
Old 03-12-2007, 10:30 AM
ttboydfw's Avatar
You can try putting two nuts on the stud and tighten them together. Then using a wrench on the lower nut and turning it the top nut will keep it from loosing and the stud should turn. Good Luck
Old 03-12-2007, 10:42 AM
SideStep's Avatar
HEY! I will give that a shot...
Thanks...
Old 03-12-2007, 10:51 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
You beat me to the advice....LOL
That will work for sure....Let us know Scott
Tony
Old 03-12-2007, 11:02 AM
vettenuts's Avatar
I'd be interested to find out if you got this out.
Old 03-12-2007, 11:18 AM
Randy WS6's Avatar
Try this, Knurl grip stud extractor ,scroll down the page and you'll see it. This is what i used.
http://www.mcmaster.com/ctlg/DisplCt...lip&ToolsetAct=
Old 03-12-2007, 12:42 PM
SideStep's Avatar
Thanks everyone... if the double nut ( ) trick does not do it I will grab the Knurl-Grip Stud Extractor from McMaster...
FYI, I also found it at JEGS:
http://www.jegs.com/webapp/wcs/store...0002_751012_-1
Old 03-12-2007, 01:02 PM
Studytime's Avatar
The double-nut trick will remove stubborn studs that the (Snap on) extractors just laugh at.
Ben T.
Old 03-12-2007, 04:05 PM
vettenuts's Avatar
Actually, the best tool I found was the Snap-on stud extractor, will not damage threads and works great. Just not sure on the ARP studs as they are rolled threads but it should work OK.
