cam question.....
cam question.....
Some opinions from you guys would be appreciated.....
What do you think of the following setup as far as a strong, reliable, and stock-like drivability head/cam setup for my 99 m6 ws6 bolt-on car:
-afr 205 heads milled to 61 cc
-cometic 0.040" head gaskets
-LPE GT2-3 cam
-LS6 intake
-qtp 1 3/4 headers and offroad ypipe
-ported stock throttlebody
-asp underdrive pulleys
-directflo lid
-corsa exhaust
-stock rear 3.42 gears
I am looking for a nice boost in useable power with excellent stock-like drivability as well as a smooth idle and a near-stock rev limit. Dyno numbers are not important, just an enjoyable sunday cruising car for the girlfriend and I with the ability to lay some smack down when needed. A visit to the track maybe once a year as well at the most.
-LPE GT2-3 cam
-LS6 intake
-directflo lid
-corsa exhaust
I would check 216/220 .525.532 .114 comp cam
the big decision will be if you want 25K spring changes or not. The cam you picked and one listed should have long spring life.
